starter WD45 |
Post Reply ![]() |
Vinnie/S.D. ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Sioux Falls S.D Points: 69 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Oct 2010 at 9:49pm |
will a starter off a WC Allis chalmers fit on a Allis WD45 I need to know if the one on the WD45 is bad or not ?
Kip-Utah ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Southern Utah Points: 874 |
Yes it will bolt up and the stater drive is the same, BUT the starter switch will be on the wrong side. I did this the other way around putting the 45 starter on a WC. I solved the problem by converting to a solenoid & starter button. Kip
Post Reply ![]() |
