WD45 copper head gasket
ACmutt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Topic: WD45 copper head gasket
    Posted: 15 Feb 2023 at 6:22pm
Does anyone know the best place to purchase a copper overbore head gasket?
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2023 at 10:01am
I would check with Clark Copper Gasket
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2023 at 10:16am
I've always made my own for engines needing them. Get a piece of copper and cut some holes. no big deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2023 at 10:31am
WHY do we need a copper head gasket for a WD45 ??  Thy don't hold back coolant very well.....like not at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2023 at 12:47pm
Dr Allis, what would you recommend for a 4.40 bore, high compression engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2023 at 5:12pm
Copper gaskets don't belong on farm tractors and this is the section you are in. Yeah, I've used cooper gaskets over the years and like I say, there is often times water control issues, so use something on it to try and keep the water where it belongs. For years I had to drain my blocks after the last pull of the day and refill with water at the next event to keep the engine oil water free. Disable the radiator cap so it doesn't build pressure. Maybe you'll be lucky and the block won't split down the middle, which forces me to run no coolant, but my bore is bigger. Copper gaskets work best controlling compression when a groove is machined into the top of the block for a wire, which then crushes into the copper  gasket for a positive seal. I locate my wire groove on the O.D. of the sleeves edge to the block deck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 6:31am
When I make a copper head gasket I use O-Rings for all the water and oil holes: NO leaks. I agree, a farm tractor should do just fine with a stock head gasket and not need a copper one.
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 6:42am
If for any reason you or anyone else does need a copper gasket, this looks like the place to go:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2023 at 9:00pm
Use original gasket cut to edge of sleeve. Then make steel orings .010 -.015 thicker than head gasket. Use silicon or gasket eliminator  around all oil and water holes. Forger the copper.                    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmutt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2023 at 5:49am
👍Will do. Thanks for your help MACK.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 4:29pm
Dr Allis is right, but you may be interested in the reason why, which he does not explain!!!
Copper and iron(steel) are quite far apart in the electromotive series(a measurement of chemical and electrical activity-see Wikipedia) so that in the presence of water when the two metals touch the copper(or brass) is dissolved to copper oxides and sulfates(greenish-yellow). This is not instant, may take years to become obvious, but will eventually be a problem, as I found out when I installed a block heater on AC170 gas!  I knew this but had forgotten my chemistry class, too long ago!!
This is why the smart plumber who properly installed your hot water heater to a copper line plumbing system installed a special pipe union(a dielectric union) which keeps the two metals from touching!
This page was generated in 0.103 seconds.
