generator with 2800 or2900 engine
elmer.marsden@yahoo. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elmer.marsden@yahoo. Quote  Post ReplyReply Direct Link To This Post Topic: generator with 2800 or2900 engine
    Posted: 14 Feb 2023 at 7:45pm
I have a 2800 pr 2900 engine in my 65kVA generator. has not been used several years now will crank but not start, has a working block heater and fuel is getting to the input on the injection pump, what now?
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 11:27am
If you don't have fuel at the injectors, then either the metering valve or the pumping plungers in the pump are stuck. Pump will have to be rebuilt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2023 at 12:32pm
I hope it doesn't have biodiesel in it setting around that long.
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2023 at 3:17pm
Are you getting any grey smoke out of the stack while cranking?
This page was generated in 0.281 seconds.
