Number of teeth on B or C starter Bendix |
Post Reply ![]() |
Allis Barn ![]() Bronze Level ![]() Joined: 02 Jan 2010 Location: Virginia Points: 42 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Feb 2023 at 4:02pm |
I have a Delco starter bendix with 10 teeth and another with 14. Is either one correct for a B or C? Was there a change in the starter for the B for different production years.
Thanks Bob
Larry in NC ![]() Orange Level ![]() Joined: 09 Feb 2016 Location: NC Points: 1050 |
14
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88248 |
10 tooth might be a D10-14 starter.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12009 |
The B,IB,C,CA used two Starters. Delco 1107043 & 1107096. Either will work in these models and both are 14 tooth drives. Steve@B&B
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24734 |
D-14 has two versions original 6 volt tractor(has brush cover band on starter ) had 10 ? 12 volt , no band , has 9 I may be wrong, well probably, still thinking about the corn field... They have different ring gears !!! Yeah I found THAT out..... I assume the different gears and ratios were cause the 12V spun faster ? |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6081 |
I got one that has 12-1/2...
![]() Edited by DaveKamp - 12 Feb 2023 at 8:52pm |
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1345 |
And I have one with only 11-1/2, now I know where the other half went! ![]() |
Post Reply ![]() |
