D 15 valve tappet adjustment
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 valve tappet adjustment
    Posted: 10 Feb 2023 at 3:38pm
Just checked mine ( 149 gas engine ) and they're all about .015" . Some are a bit looser than others . Just wondered if anyone has a foolproof way to do this ?  I had trouble keeping the gap from moving when I tightened the lock nut . Guess it would help to have an extra pair of hands . Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2023 at 4:44pm
.015" COLD is what you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2023 at 5:19pm
Thanks Dr Allis. I'm checking them cold and I set them at.015" cold last summer. Just hard to get them all just right. For me anyway. On some my feeler gauge doesn't have the same "drag"
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2023 at 1:29pm
Seems someone was asking about valve adjustment recently . I'm sure I learned it from this forum . Probably Dr Allis . THANKS ! Cold engine , pull plugs , big screwdriver in timing hole on flywheel teeth turns engine . Get #1 on compression stroke . On my engine the crank set screw is up , adjust #1 . Turn engine 1/2 turn , set screw down . Adjust #2 . Another 1/2 turn , adjust #4 . One last 1/2 turn , adjust #3 . Set all mine so there's a slight drag on the .015" feeler gauge . Hope this sounds right to everyone . THANKS again
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2023 at 1:31pm
ACinSC, purchase a go-no-go feeler gauge set.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2023 at 1:40pm
THANKS Clay , just googled go no go feeler gauge . Never heard of them , have to get a set . I can use all the help I can get . THANKS , again !
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2023 at 2:07pm
Just checked my engine compression . #1-135 , #2-140 , #3-145 , #4-150 . Still leaks down but not nearly as quick as before the head rebuild . Guess it's leaking past the rings ? A new set of Autolite 295 and I'm done . THANKS !
