PTO bolt
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: PTO bolt
    Posted: 07 Feb 2023 at 2:32pm
I was blowing snow with the WD-45 today at the cabin and all was well then not well. The pto shaft stopped going. The bolt for the gearbox to extension shaft was gone. Is this a special shear bolt? I will buy the bolt, but if I can source it locally I would prefer that. What does everyone else use? What size bolt would I need if I can just use a bolt?  Thanks for a reply. Mike
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 3:45pm
A pic would help verify this, but it is highly likely the missing piece was a shear bolt.
I would only replace it with same or weaker spec shear bolt.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 3:49pm
The factory bolt is a shoulder bolt. Just checked with a Agco dealer and price was around $30.00.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 3:57pm
most probably just use a soft grade 2 plated bolt from the hardware store.. You need a lock nut or something to keep it from falling out... should shear the bolt if you hit something hard.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 4:00pm
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 4:07pm
Do not do what one guy did.  He was buying his second pto gear from me when I
asked him what he was using for a bolt.  He said a Grade 8.  I told him he needed to
go way softer.  He has not been back  I'm guessing he took my advice.   Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 4:13pm
the shoulder is so you can bottom out the nut and have it TIGHT so it will not back off... Using a selastic nut with a grade 2 bolt will do the same think... dont want the nut to vibrate off.
Edited by steve(ill) - 07 Feb 2023 at 4:14pm
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 4:39pm
Thanks for the input. But since I don't have the old bolt does anyone know the size? I can't measure  because the tractor is 2hrs away. Sorry to be a bother.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 4:41pm
I have seen 7/16 and 1/2 inch in various shafts .... just take a couple bolts... if they are an inch too long, that dont hurt.
when you get the size, keep a couple spares in the tool box. Wink
Edited by steve(ill) - 07 Feb 2023 at 4:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 4:46pm
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 4:47pm
Thanks I didn't want to just put a bolt in and do more damage. Learning things as  I get older.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 6:10pm
The design of the bolt is such that when you tighten the nut tight, you are not crushing the tube onto the PTO output shaft. The bolt floats in the hole.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 8:15pm
Make sure you don't have threads in the bolt hole when drawing nut up tight.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2023 at 9:54am
Doc makes a good point. If you ever want to pull the pto shaft, which is recommended for moldboard plowing, you don't want it crushed. My thinking, and I could be totally wrong, is that bolt was NOT designed to be a shear bolt.
