7020 oil leak between front plate and engine
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Topic: 7020 oil leak between front plate and engine
    Posted: 07 Feb 2023 at 6:26am
I've got a 7020 that has developed a pretty significant oil leak between the block and front mounting plate. I've never tackled this repair before, not sure I want to. How big of a job is it, I assume that I'll need a jack under the front of the engine to support it. Might have to loosen frame rails a bit and will I pull the camshaft out, or just pull the gear off. Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 7:22am
You will need to rebuild or replace front plate and dowel pins. Not a small job.                          MACK
