WD 45 hydraulic problems.
bikergreat1911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikergreat1911 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 hydraulic problems.
    Posted: 06 Feb 2023 at 11:43am
Hello, i got a WD 45 that the hydraulics dont work at all. Everything looks to be correctly set up. ( i did move Everything around just in case it may have been stuck.) With no such luck. If i move the arms up & down it does create pressure  when i push in the remote. Also when i turn the handle to the up position no sound from the pump like on my WD.. I'm new to these tractors any info would be great. Thanks
Youtube channel= rgs adventure
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 12:30pm
The owners manual is a great place to start. There are several linkages that can be adjusted and the manual tells how to set them up correctly. You don't say if they never worked or if they suddenly stopped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bikergreat1911 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 1:29pm
It never worked since the day I got it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 7:57pm
If you have a WD and understand how the hyd pump should work, sounds to me like it's time to remove the pump and go thru it. This assumes the oil level is correct.
