Shameless ,you're on camera !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: Shameless ,you're on camera !!
    Posted: 03 Feb 2023 at 1:28pm
Seems the Chinese are sending realtime video of the 'machine of your in action !!
They launched a 'weather balloon' that , um, ah, got of course and it's headed your way !!!
It's 'interesting' that no one seems to give a ratz behind that's it's gathering gigabytes of data and streaming it back to China.....
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2023 at 2:00pm
 Yep their going to catch him
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2023 at 4:05pm
dont be runnen around the yard nekid !!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2023 at 4:06pm
There is so much more to that than we'll ever know. The Chinese are way smarter than to spy with something that obvious
Darrel
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2023 at 6:57pm
Shameless should give them a good show, Remember you can't unsee it.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2023 at 6:58pm
ya know Darrel,, it may be just that easy,, you know,, hidden in plain sight....
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2023 at 8:57pm
  The BIGGEST issue here is that the current administration don't seem to give a rats' patoot and have given orders to stand down,,at least till they get all their filming done,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 12:46am
my place is a "no drone zone", would a balloon apply? target practice?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 4:33am
Barrett .50 cal could do it from the ground, with the right dope on the scope...Wink
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 5:22am
Runnen round nekid would probly brAk thu camra. Yud be a nashnal hero!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 6:07am
DJ hit the nail on the head !
There's a huge amount of information that reconballon has and is sending back to China every second it's over your country. The 'line' about not destroying it over population is BS of course. A simple LASER can burn holes in the balloon and it'll come down nice and easy,but ten someone wouldn't get his 10%.....
it'll be interesting to her what happens when it gets over Europe though !!
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 6:50am
Americans always do the right thing after exhausting the alternatives! Winston Churchill I believe that with the situation reversed and an American Baloon was over China it would be shot down!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 6:54am
yup, and my IDIOT would assist the balloon, give it free energy, WIFI hookup, Cell relays,etc.....
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 10:20am
Neither a Barrett, nor a laser from the ground would be effective.  It's altitude is 60,000ft.
IF the .50 could hit say... 4000fps, and the projectile could MAINTAIN 4000fps, it would require 15 seconds of flight time just to REACH the altitude.  Without auxiliary rocket power in it's taper, the .50 (12.7mm) will have lost all it's kinetic energy before crossing 2500ft.  In comparison, the German 128mm FLAK40 could peak to 48,500ft...  that's still short.
Now, if you were in an aircraft flying at that altitude, you'd have to be moving a bit fast.  A quad mount of .50's leaving a strafing trail MIGHT do it, but in WW2, the 50's, and many 20mm cannons failed to operate at higher (meaning, 30,000+) as a result of temperature being so low that they wouldn't operate (wouldn't cycle or fire).  The tactic used THEN, was to come in at lower altitude, dive (to pick up speed), then pitch up (to 'arc' a shot) and fire ABOVE, in hopes that the projectiles would come back... but you're still looking at a short range of only a few thousand feet.
Lasers don't do a good job cutting through water vapor, or anything reflective.
The proper weapon here, would be a U2, and a good-ol' fashion Mississippi River Trotline.  250ft of 200lb test cord with 100 or so treble hooks spaced every two feet, and a breakaway clip at one end tied to the tail of the plane.  Fly around for a look or three, then pass over top to introduce a little ventilation.
The balloon is probably doing several things, first is recording sensitive comms, the second is probably gathering any wifi/network access info... last is taking pictures.
You'll hear the 'suits' saying it is 'just weather' because 'inferior to satellite'... well, that's not true.  Satellites can do quite a bit, but the balloon functions closer, which means it has the ability to focus it's listening on specific points with much greater immunity to large-area signals.  Effectively, it can perform the electronic equivalent of eavesdropping on a personal conversation amidst a rock-concert.  Let's say that ballon can connect to your cellphone, or your TV, or your Wi-Fi computer via a hardware 'back door' in it's Chinese-made chipset... that balloon, at 60,000ft, will get a full signal strength on your cell, TV, or WiFi device (Hey Alexa...) to pick your house, and select which device, they want to hear.
Unlike satellites, ballons have basically an indefinite loiter time... they can 'park' over an area and just do their work.  Satellites follow orbits, so unlike the 'movie' bits (where someone calls a satellite to 'go somewhere and do something', they can only 'sweep' as they pass by at some elevation and velocity.
What we SHOULD do, is strip-hook it (as noted above) with a parachute array on the hook, ventilate it, and as it falls, pop the chutes so it lands softly, for recovery and analysis.
What we'll most likely find, is that as it falls, there will be integrated devices (pyrotechnic and chemical) that cause it to self-destruct, at which time, it will be prima-facie evidence of being something other than ''meteorologic study".
Edited by DaveKamp - 04 Feb 2023 at 10:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 10:30am
I think an F16 can hit 50,000 ft......... but a F22 can go 65,000 ft ..... close up and personal !!  Wink
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 12:59pm
Balloon prolly is made out of some kind of kevlar or rubber that can/will withstand lots of pressure. Think the treble hooks would maybe not penetrate material and slit it.
Thing might be 60 ft diameter or greater, like maybe 300' +/-. Haven't heard how big it really is.
  Since your going up with an F22, mount the laser cutter on it and start cutting as you fly at the balloon.
 Now there's two of them floating around...
 No body has said a word about the 'what ifs', if it were filled with more covid crap... or some other disease or chemical... or some wmd device...
 Should have destroyed it when it was traversing across the top end of the world.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 2:16pm
I just got a news beep on my phone that it was shoot down of the coast of the Carolinas
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 5:01pm
Published
Pentagon reveals details on how Chinese spy balloon was taken down with single shot
The Chinese spy balloon was shot down by a single missile from an F-22 Raptor, according to the Pentagon
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 5:03pm
A senior military official said on Saturday that the Chinese spy balloon was shot down at 2:39 p.m. on Saturday by one air-to-air A9X sidewinder missile fired by an F-22 Raptor that took off from Langley Air Force Base in Virginia.
The aircraft fired the missile at an altitude of 58,000 feet while the balloon was hovering at an altitude of between 60,000 and 65,000 feet.
The balloon was shot down about six nautical miles off the coast off South Carolina and the debris field is said to be roughly seven miles wide.
Edited by steve(ill) - 04 Feb 2023 at 5:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 7:20pm
The U.S. military is working to recover the Chinese spy balloon that was shot down off the coast of South Carolina Saturday by a U.S. military fighter jet and expects to gain valuable intelligence from what it finds, the Department of Defense said.
As part of the recovery mission, several U.S. Navy and Coast Guard vessels established a security perimeter surrounding the area in the Atlantic Ocean roughly six miles off the coast where the balloon crashed after being shot down, DOD officials said. The vessels are searching for and collecting any debris associated with the balloon.
Because the device fell into a relatively shallow area, which has an estimated depth of 47 feet, the recovery mission is expected to be "fairly easy," one official stated. However, officials said there was no estimate for the length of the mission.
Edited by steve(ill) - 04 Feb 2023 at 7:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 8:50pm
I know what they'll find...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 8:52pm
Excellent!  Do 'em ALL.
" I think an F16 can hit 50,000 ft......... but a F22 can go 65,000 ft ..... close up and personal !!"
Any modern fighter can bring down higher-alt targets with an AAM, provided they can vector it into the frame and lock on... AND... that the target doesn't have strategic countermeasures.  The problem with taking a shot like that, is having the bird miss it's (otherwise stationary) target, and loop around, but come back to find YOU instead.
The balloon can't dodge, but it doesn't have much of a signature, and it is otherwise a small target.
Bringing it down in one piece grants some significant intelligence data... just gathering and reassembling the antenna arrays tells us what bands, and what bandwidths it can 'work', as well as how narrow it can focus, which in turn identifies how weak a signal can be, and STILL have it grabbing info.  Being able to extract it's electronics package will readily identify wether it's a listen-only, or capable of transmitting too (which means, it's not Electronic Surveillance, it is Electronic Warfare).  Obtaining it's sensory package identifies just how much 'weather' it really is capable of gathering, as well as it's navigation and telemetry protocol.  Once assessed, that will identify what type of command system it uses, what it's satellite uplink and downlink carry, and from this, just how 'lost' it really was.
In the meantime, if they can't bring 'em down unscathed, turn them all into dust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 9:40pm
Interesting part of all this, is that DesertJoe is so intimately related by virtue of his location... Project Mogul... 1947... NYU Flight 4...
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2023 at 9:54am
 Yep, Dave,,,the G-men always looking out for it's citizens,,,,?  The local Sheriff's Dept was alerted by the rancher who found the crash site on his land the next day after a horrific lightening storm that night. The Sheriffs deputies went out (about 50 miles) to investigate and reported to the local Newspaper ( Roswell Daily Record) which ran a front page article with a huge headline!! When the brass at Walker AFB became aware of the discovery, a bunch of airmen were sent to "retrieve' all traces of the discovery. Three additional sweeps were done. All the wreckage pieces were taken to the air base and stored in a huge hanger, and THAT hanger still exists today but has been "medically Cleaned" All of the wreckage was (suppossedly) transported within one week by air force planes to Wright Patterson AFB base in Ohio. The Air force official that was quoted by the newspaper later displayed some pieces of what was explained to be " A Crashed Weather Balloon" but NOT a Flying Saucer,,,,,,,,,,? Within a week, every airman that was sent to crash site to retrieve the remains was re-assigned to a different air base all over the world,,,BUT,,,,no two airmen went to the "same" air base,,,,? Believe it or else,,,,, We ain't alone out there, men.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2023 at 5:27pm
This page was generated in 2.172 seconds.
