CA rear rims 10x24
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: CA rear rims 10x24
    Posted: 26 Jan 2023 at 4:58pm
Guys I have power shift rims that need work. What are y’all replacing them with since we really don't Need to power shift them? Thanks amigos! Dana
Blue Skies and Tail Winds
                          Dana
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2023 at 5:22pm
D-10 and D-12 will bolt on.
Power Shift Rears were Optional on a D-10.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 9:00am
But how do the new rims with the 4 loops work idk?
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 9:00am
something like this........
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 9:02am
Yes Steve I have to run up in the shop and see how those will work
                          Dana
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 9:36am
The 6 lug  centers used as on option on D10's are the same used on a lot of tractors like Farmall Super A through 140's.  My Cockshutt 20's  and Oliver 440 even use them.   You need to find a set of centers and then the four loop rims will work.  Cheapest option is to find the used centers and rims together.
Edited by Larry in NC - 27 Jan 2023 at 9:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 10:31am
pretty sure old, GMC truck tims fit.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 11:23am
So here’s what I have, how would those loop rims work?
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 11:38am
I posted a picture above, you have to change the centers to use four loop rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 12:38pm
Oh oh oh! Gotcha now! Thanks!
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 12:43pm
Dana, i dont know your mechanical / welding ability or who you know with that... The easy way to adapt is to buy a new steel hub that has 6 bolt center, and 4 holes to fit the LUGS on the rim..
If it was me, i would make 4 plates that BOLT or WELD to the original hub, take the 4 present spin out mounts off the hub, and adapt that hub to fit the new rims.
Edited by steve(ill) - 27 Jan 2023 at 12:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 1:15pm
Someone ought to go into business making a set of 4 -6 plates to adapt the D series (with spinouts)... using 4-6 loop rims to the Original Hubs... 24- 26- 28 inch.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 6:03pm
Dana
It appears you have all the eccentric components to maintain the original Power Shift Rims.
So bite the bullet and get new Power Shift Rims.
Forget about cobbling something up with welded parts.
In the end you will be glad you did.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 7:27pm
how often do you use the power shift  ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2023 at 4:30am
Steve I NEVER use ps rims. I think making brackets using my centers sounds better than $600 new ps rims! I’ll prolly just get inside of these rims and fix them like I have done before. Thanks to all.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 2:09pm
I have a D10 that I bought from an estate in Maine that did not have power adjust rims. The daughter that I bought it from really knew nothing about it other than it was her dad's and he used it for parades.
I'm thinking that the centers are not AC, but I'm not sure of that. Here are a couple pictures I took today when I was down where the tractors are.
This page was generated in 0.166 seconds.
