Looking for D15 diesel main bearings
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Topic: Looking for D15 diesel main bearings
    Posted: 26 Jan 2023 at 7:16am
I’ve got my D15 diesel Industrial backhoe engine tore down. Im looking for the main bearings for the crank shaft. Which is getting ground to .030” under. Any leads or help would be appreciated.
Ray Walker
(269)804-5984
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2023 at 10:52am
Good Luck with your search.
I just rebuild the Diesel in my D15 2 years ago and It was a struggle to find standard bearings.  (Or any parts for that matter)
these thinks pop-up once in a while.
hopefully someone here can help.
You can check with: Pfouts family farms in Ohio 1-330-569-7037
they advertise on this site.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2023 at 11:35am
I Googled and Yesterday's Tractors and others have the std. main sets.  Instead of turning the crank under, is having it built up and turned to std. and option?
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2023 at 4:27pm
Aren’t they the same a D17D? Just fewer of them?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2023 at 5:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2023 at 6:00pm
I’ve talked with All State Ag, Reliance & Jen Sales. All out of stock. If I could find a standard set. Having the crank mains built up is an option.
Joe, those bearings are for the D17 or D19.
I believe this engine to be a 175cid.
Edited by Rltool - 26 Jan 2023 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2023 at 8:43pm
Joe(TX) I looked at the specs for the D17 D226 diesel compared to the D15 D175 diesel. And it looks like those main bearings will work for either one.
Thank you for the information.
Ray W.
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2023 at 11:21am
Ray,
I should have a set, give me a call. Pfouts Family Farm LLC 330.569.7037
Mark
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2023 at 6:40am
They are all the same. D15D, D17D, D19G/LP, and D19D all use the same main/rod bearing.
I ran into this when I redid my D15D Years ago. No sets in stock for a D15D (175CID) but PLENTY of stock for D17D (262 CID). Just ordered them for a D17D and had some main bearings left over that I didnt use.
All the 175CID engine is is a 262 6 cylinder with back 2 cyinders missing. Bore, Stroke, rod, are all the same
1968 D15D,1962 D19D
