sealing bad D8H head crack (pepper?)
wrwtexan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wrwtexan Quote  Post ReplyReply Direct Link To This Post Topic: sealing bad D8H head crack (pepper?)
    Posted: 10 Oct 2010 at 11:02pm
 I have an old Cat D8H farm dozer which is blowing water out the exhaust and pressurizing the cooling system. I sealed it several years ago with KW, but recently got it hot and it opened up again.  This time the KW did not work and with the size of this machine and the time it is run per year, I want to try a quick fix.  Does black pepper work very well for crack sealing or is there something else better.  It is a 20 gallon system so expensive small engine sealers are too expensive a gamble.
220, 190XT, 2 D17's, WD45, 2 CA's, C, M2 Forkbine
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 11:19pm
This stuff is not that cheap but it may just fix that crack once and for all.
http://www.heal-a-seal.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 6:22am
I know this isn't a cheap fix, box up the cracked head and ship it to Midwest Cylinder Head in Nevada Iowa. If it's cast, they can weld it.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 6:27am
cornbread works better. belzona is the best liquid glass second in my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 6:43am
flax seed meal, get it at your drug store or health food store.
Bars Leak block seal powder , worked on my UD14 IH engine head on grader
Edited by Coke-in-MN - 11 Oct 2010 at 6:45am
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 8:47am
Good lord, you are taking an expensive gamble trying to seal things like that.  Take the head off and get it stitched up(pinned), or if you like to gamble slightly more, welded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 11:48am
Sounds like Brick and I agree. Around here Midwest Cyl Head has a very good rep fixing cracked heads and blocks.
