AC Items for sale, possible delivery to Swap Meet
Michael Crowe View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Topic: AC Items for sale, possible delivery to Swap Meet
    Posted: 23 Jan 2023 at 10:03am
I'm not completely getting out but I am downsizing. The following is for sale and possibly can be delivered to the swap meet at no charge.
I started to rebuild two motors and one tractor purchase fell through and I decided not to bother swapping the original motor back in since its temporary replacement runs so well. So here are the particulars.  Both motors are complete and in partial reassembly stages.
WD Motor 1: WD block, crank turned .20/.30, new bearings, NOS AC engine kit with original 5.7:1 compression pistons; new cam bearings.  The pistons, sleeves, rings, cam, crank, and new cam, crank and rod bearings have been installed, the rod and mains are not torqued.  All it needs is for the bearings to be torqued and shimmed to spec and the head and valve train put back on.  I have NOS shims and a NOS all metal head gasket.  The head was redone with all new valve train.  I have everything you need to have a complete engine when you are done, minus a carb, manifold, magneto, waterpump.  I will include the flywheel.  The block has no cracks top or bottom.
WD Motor 2: WD block, standard crank polished, NOS standard main and rod bearings.  I had a set of NORS .040 oversized pistons and rings that were used during the war years when steel was scarce.  I took the pistons to a very reputable machine shop and he bored them out to .040 oversize and honed the sleeves.  The pistons, sleeves, rings, crank, and new crank and rod bearings have been installed, the rod and mains are not torqued.  All it needs is for the bearings to be torqued and shimmed to spec and the head and valve train put back on.  The only difference between the other motor I have is I have not installed the cam or cam bearings.  I have NOS shims and a NOS all metal head gasket.  The head was not redone but checked out.  I have everything you need to have a complete engine when you are done, minus a carb, manifold, magneto, waterpump.  I will include the flywheel.  The block has no cracks top or bottom.
Also the following implements:
AC Oxnard toolbar 7 shank ripper, i shank missing, complete with all mounting pieces
AC Oxnard toolbar sub soiler, complete with all mounting pieces
3-16 semi mounted slat plow, gauge wheel, good tail wheel, optional top support bar
3-14 plow, has 3 coulters, 3 extension to help turn dirt over
SC rear blade hitch assembly (its laying on top of the plow)
AC Oxnard rear blade with the Oxnard toolbar hitch
AC Rake/Tedder with optional dual wheels on both ends, all broken teeth replaced, works good, gearbox good
AC Roper post hole digger, excellent and complete, I've used it several times over the years
AC WD45 LPG tank with new valves
AC mounted chisel D19 size, complete with gauge wheels on both ends
AC Oxnard toolbar hitch NOS D19 size
Rotobaler
Many other NOS and used parts, mainly for WD's and WD45's, gas, diesel, lpg and distillate.  Items that are paid for or other arrangements made I can bring to the swap meet at no charge but my trailer is only 18' so once it is full, the buyer will have to make arrangements to pick up whatever I can't fit on the trailer at my farm in Harrisonville.  Call me at 816 898 7277 or email me at mcrowefarm@gmail.com to reach me the quickest.  I'll respond to PM's but I only check it one in the evenings during my busy season.  Thanks. Michael
Edited by Michael Crowe - 24 Jan 2023 at 4:39pm
The 15th Annual Exclusive AC Swap Meet will be held in Boonville, MO, March 6-7, 2026. See the club website for details: http://www.moacclub.com/
