fuel shutoff solenoid
rbaggett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Topic: fuel shutoff solenoid
    Posted: 21 Jan 2023 at 1:50pm
I have a 6080 AC that is getting fuel to the injection pump but will not start.  I have power to the fuel shutoff solenoid when the switch is on but I don't hear it click like it normally does and I am getting no fuel to the injection nozzles.  Does anyone have any suggestions on how to fix this.  It was starting just fine this morning but when I went back to start it would not start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2023 at 4:03pm
If it isn't clicking and you're certain you have good power to it, the shut-off solenoid is bad. You might try and run a new wire from the battery post on the starter hot cable direct to the injection pump and see what happens. Just because you may light a test light doesn't mean it is a good 12 volt signal under load.
