201 push rod side cover..
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Topic: 201 push rod side cover..
    Posted: 19 Jan 2023 at 4:31pm
...saw the post below - was the heritage of the engine such that there were adjustments under there as in an earlier version  'Leroi' possibly ?  Or was it just a 'thing' they did back then?  Flat heat engines were like this...  just a thought... any ideas ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 5:14pm
I always thought A-C hadn't finely honed their casting skills until the WD45 engine block!! But, there's something to be said for being able to clean the sludge out of that area, as they were using non-detergent oils from the WC (1934) thru the WD (1953).
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 7:46pm
Chev 250 inline 6 cyl had side cover as well. Sure made it easy to change bad lifter. I had one in a 71 Ventura (like Nova). Drove from North of Toronto here to Los Angeles. One lifter was clacking badly when we got there. Removed rocker cover and side cover. Installed one new lifter and drove the car for years after. Took maybe 1/2 hr to do. Sure had some comments about backwoods Canucks doing repairs in driveways!
Cost of repair was less than $20. Smile
Edited by Ed (Ont) - 19 Jan 2023 at 7:48pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 9:18pm
Ford Sixes have that lifter cover too, definitely a troublesome spot for oil leakage.
