TL12
jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jim Quote  Post ReplyReply Direct Link To This Post Topic: TL12
    Posted: 19 Jan 2023 at 8:26am
Have a TL12. Engine is bad. Can't remove the oil pan as there is no clearance. Not sure how you can pull the engine as you would have the same issue. Does the rear counterweight have to be removed to allow engine to be moved rearward to allow removal? Machine has the WD45 gas engine.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 10:59am
I dont think you can pull the engine without taking the rear section off.  i did on mine,  left the top braces on and pulled it out.
jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jim Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2023 at 5:52pm
Do you mean the radiator and rear grill or the rear weight and axle bolster as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 7:09am
axle does not need to come out.  remove the heavy iron that holds radiator in 1 piece.  take the cast grill out first.  I got both with a cherry picker, nothing special except 4 big bolts on bottom and bolts on upper braces at the rear going to radiator section.  no need to remove the braces at the front.  converter stays in trans housing,  engine has a splined coupler will slide right out after 8 flywheel plate bolts.  again no need to remove rear axle or weight/hitch.
Edited by CAL(KS) - 20 Jan 2023 at 7:10am
jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jim Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2023 at 6:14pm
Thanks
jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jim Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2023 at 5:42pm
Another question, Do you remove the rear lift cylinder pins so cylinders can be left on the machine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 11:10am
yes, I left my cylinders attached to the rod end so the barrel ends will just hang down out of the way.
Edited by CAL(KS) - 24 Jan 2023 at 11:51am
jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jim Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2023 at 6:48pm
thanks
This page was generated in 0.169 seconds.
