WD pushrod cover |
Post Reply ![]() |
AllisFreak MN ![]() Orange Level Access ![]() ![]() Joined: 07 Dec 2009 Location: Minnesota Points: 1589 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jan 2023 at 7:05pm |
I am replacing the dried up cork gasket on the pushrod cover on the ol' WD. Any tips as far as using permatex or should I just put it on without any?
MACK ![]() Orange Level ![]() Joined: 17 Nov 2009 Points: 7664 |
Glue it to cover with 3M1099 glue or that yellow weather stripping glue. Let it set over night with weight on it to keep it in place. Install next morning. MACK
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1345 |
I've been messing with this stuff for 50+ years now; my Dad always used Permatex Aviation #2 gasket sealer. It is messy, sticky, gets on your fingers, in your hair and is miserable to scrape off the next time.
But it works. When I got out on my own I read about folks saying that a properly prepared gasket surface didn't need goop to seal, so I tried and failed. I tried silicones and I tried various things with varied results. When I really, truly don't want to mess with it for a long time I still go back to Permatex aviation gasket sealer. Your mileage may vary. Good luck :-) |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8655 |
I use MACK's method successfully
Dirt Farmer ![]() Silver Level Access ![]() Joined: 15 Sep 2020 Location: Illinois Points: 444 |
Im in agreement with Mack and Steve. Around here we refer to it as gorilla snot
Eric B ![]() Orange Level ![]() ![]() Joined: 09 Feb 2012 Location: British Columbi Points: 978 |
X2 for Les Kerf. I know different methods and sealers will bring results but in my opinion Permatex Aviation is at the top of the success list. Silicone Ultra Grey will really resist oil leaks. Using Permatex Aviation on both sides makes an awesome seal but the gasket is rarely reusable if you remove the part again in the future.
LaJaMe ![]() Bronze Level ![]() Joined: 14 Sep 2014 Location: wisconsin Points: 172 |
When my Dad was a dealer, he would shelack the gasket to the cover and then grease the block side. This was so he could get the cover back off if valves needed readjusting. He never had a problem!!!!
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Indian Head Gasket shellac is my go-to on cork gaskets.
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2486 |
if ya do like Mack says,, that gasket will defiantly stay on the piece its glued to.
I like the permatex aviation or whatever is similar, it stays kinda soft and seems to seal decent,,,
Yup I did as Mack said and it worked great. Man was there a lot of old sludge behind that cover and the old cork gasket was rock hard and brittle.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22059 |
I think that is why they had that cover removeable was to be able to clean the engine due to non-detergent oils.
Post Reply ![]() |
