My NFE FPS ‘45 |
Post Reply ![]() |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jan 2023 at 5:07pm |
Hey my friends I took a ride instead of shop work today, bought anotherHD bench for my new heated shop too. I did take a few minutes while bullying the new to me bench through the doors and ran a compression test on her. Every cyl shot the gauge to between 145 and 150 psi which I’m confused as I didn’t think they should be that high? Is this kosher? Enjoy every day. Dana
Blue Skies and Tail Winds
Dana |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5903 |
while bullying the new to me bench through the doors and ran a compression test on her. That's a new one on me ! How do you run a Compression Test on a HD Bench? Take FEL and push the Bench up against a wall? Any pictures ? G ------- L O L ------- |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4107 |
145 is about spot on for M&W pistons. Got an engine kit from Tony years back, it makes about 150.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22062 |
Or OEM D-17 4 inch bore pistons are 145 psi.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5041 |
If you stick a borescope camera in the cylinder, you would be sure what you have for pistons.
Post Reply ![]() |
