Generator Information Needed
RJMW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RJMW Quote  Post ReplyReply Direct Link To This Post Topic: Generator Information Needed
    Posted: 11 Jan 2023 at 1:36pm
Good morning all,
I have a customer requesting the replacement of the day tank which feeds his generator on a high rise in downtown San Francisco. Unfortunately he is having trouble providing the literature for the AC Generator.  I was able to grab the data plate information of the unit which is a Model# 6136T or possibly 6133T. (Unfortunately the data plate is a bit corroded)  The serial # is 14 04164.   We are trying to determine the fuel burn ratio so we are able to properly size up his daytank.
Thank you for any assistance you are able to provide!
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 3:29pm
engine would be 6138T.  844 cubic inch.  nebreska tractor test lab tested an earlier model of this basically same engine known as the 21000.  the 6138 would make more power but would also be more efficient depending on the settings.  at rated load the 21000 used 13.974 gal per hour.  so make 15 gal an hour is a good assumption?
here is a link to the test results paper.  finding results for this particular application could be difficult, but probably out there somewhere.
Edited by CAL(KS) - 11 Jan 2023 at 3:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 4:08pm
2100 engine was used in the 21C dozer also.. We tested one for hours in the field and it was in the 13 - 14 GPH range over many months..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2023 at 10:17pm
A good rule of thumb is 10 gallons per hr gets you 200 HP.....20 gallons burned per hr gets you 400 HP. Whatever KW your gen is should calculate to max HP required.
