HD4
Mike K View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Topic: HD4
    Posted: 10 Jan 2023 at 7:41pm
How to remove final drive shaft to remove brake on right.
 There is a pin in the shaft or is this a clip.
 cannot visual see
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 7:48am
It is a clip. I bought a 12" flat head screw driver and bent the end 90 degrees about an inch from the end. I was able to work it under the clip and pull it out. Then slide in the axle shaft.
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 8:44am
i did the same thing on mine. worked fine.  good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 9:10am
Go to the link for a picture of the clip so you know what it looks like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2023 at 9:54pm
Thanks for all the advice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike K Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2023 at 10:00pm
Once I pulled the clip the rest was easy.
all the post I googled said it was such a pain. Not so.
 Easy peasey
This page was generated in 0.391 seconds.
