EPA, Gas Stoves!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: EPA, Gas Stoves!!
    Posted: 09 Jan 2023 at 4:27pm
Have been determined INJURE people with Asthma and are Considering a outright BAN on Ownership, Working thru Consumer Product Safety Commission.  PARTICULATE Emitters.
WTH, Grandmother cooked over gas to 98 years OLD, I have been around Fuel Fumes most of my adult life, BORN with Asthma and STILL do not require inhaler or drugs to control.  These people are off the Deep end or smoking some really bad Dope!!.
Edited by DMiller - 09 Jan 2023 at 4:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 4:52pm
mybe they can equip them with a catalytic converter ,  nitrous oxide absorber and an afterburner !!   LOL   Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 6:22pm
These people are out of their minds.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 6:30pm
When I first saw this post I remembered the story of the sky diver's first solo jump. He jumped out of the airplane counted to 10 and pulled the rip cord and nothing happened. He thought ok I'll use my reserve chute,so he pulled the rip cord for that and nothing happened. Now he is scared! He looks at the ground and sees a man flying up toward him. As they meet he yells" Know anything about parachutes"! The guy yells "No"! Do you know anything about Gas Stove's"!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 6:34pm
LOL!!!  I do remember that too!
I have since moved this into Political side.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 8:17pm
Then the next items will be the 10K to 30K BTU non-vented NG and LPG space heaters.
 I had my LPG 30,000 btu running about 1/2 during the cold snap in the 30x48x16 shop overnight for 4 nights. I could tell the air was different each morning, turned it off and turned up hanging furnace. Also it leaves moisture inside bldg, all the windows were iced over and walkin door almost frozen shut. After running furnace warmer air was better and humidity went way down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 8:21pm
hmm.... wait till they ban propane BBQs !
 hmm... any regs on indoor propane forklifts ??
seems 'they' want to ban ALL gas powered devices ,force to buy ELECTRIC... so WHERE withe the electrons come from ???
Edited by jaybmiller - 09 Jan 2023 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2023 at 8:43pm
I'd forgot about all the places using LPG forklifts even with door open they stink the place up. I use charcoal in grill.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 6:45am
Long time ago in the summer between 2nd and 3rd year of college, I worked in an assembly plant.  One job involved putting a hot stamp mark into a plastic molding.  After a while, the smell of that hot plastic would about make your stomach roll.  About the time you'd get sick of it and want to turn away for a fresh breath, the dang LPG fork truck would go by and puke in your face!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 3:03pm
https://www.c40.org/news/fossil-gas-research/
According to the Green Movement burning anything is BAD - even if used to produce electric which is the NEW GOOD - as long as the electric is produced by things that do not pollute - so them towers the wind turbines go on or the tons of concrete in the base to hold them up are bad - but the electric they produce is good . Methane gas from decomposition is bad , burning trash to produce electric is bad , cooking food by gas is bad , heating your home is BAD .
  Face it you being here is bad to many as your using the things others need . So sharing is out but hoarding is in !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 4:17pm
As soon as those Green Weinies are out in a field eating Cold Grains and berries sleeping on grass pallets with a Mud Hut and natural coverings on themselves using NO GAS OIL OR ELECTRIC and Especially No Computers then I may consider adjusting my thermostat back a degree or two.
Randy WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy WI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 5:14pm
Buy it is ok to smoke weed in Mich.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 5:36pm
YEP.. I nominate the Green Weinies to be the LEADERS of the CHARGE... They make GOOD CANNON FODDER !!     Thumbs Up
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 6:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 8:57pm
Saw a short news article on TV about this. I hadn't thought about that most restaurants cook using gas appliances. The guy talking said he didn't know IF there are electric appliances available to replace his grill tops, ovens, broilers. And if available that the cost to R&R could put some out of business.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 9:59pm
Yes, it will.  The most cost-inefficient source for domestic heating, is electricity... 1kw/hr is only about 3400btu... an average home's 75kbtu gas furnace will be replaced by an electric unit pulling 22kw/hr.  If you're in my area, an average winter heatload will have that furnace running about half the day, so 12x22= 264kw/hr per day, or 7920 kw/hr/mo...
at 0.15/kw/hr, you're gonna pay $1100/mo just to keep the pipes from freezing.
Methane is bad.  Natural gas is mostly methane, but unfortunately, it has been naturally produced as a result of biological decomposition (like... composting), so we should gather up as much as we can, and burn it... to help keep the environment safe from methane poisoning and stuff.  Perhaps we could capture it in pipes, and send it to peoples' homes, so all the heat generated from cleansing it from the atmosphere, can be used for domestic use...
Propane may be a little stinky, but most of the time, if it's a stinky old forklift, it's because the valve guides and rings are well worn... but hey, that can be solved by pulling off the propane kit, and burning gasoline instead... or better yet, eliminate all the forklifts, and put a hundred employees in serious physical peril by having people just carry pallets of bricks, aluminium ingots, and all the containers of crap shipped by Amazon...
knkrein1 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote knkrein1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2023 at 10:41pm
When any of you get a chance check out the Ann Arbor Michigan politics - they are working on passing laws to ban gas stoves in any new residential and CommerSel buildings.
Ken R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 12:44am
hmmmmmmm....I wonder how much I could make...just being myself??? bacon/grapefruit/beer always go together well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 6:43am
gee Dave , don't put REAL numbers on paper.....greenies don't want to know the TRUTH !!!
You sure got cheap rates !! For me, the reality is about 25c/kWh, so I'd be close to $1700 per month...just a small increase from the $130 (CDN ) I'm paying now.....
let's see 'them' ...lead by example and SHOW us their new electric stoves and fireplaces AND their new hydro bills !!
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 7:44am
And their new electric vehicles with limited charging stations!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 8:11am
Seems the CPSC and EPA have backed away from this as to Public ANGER at the stupidity of it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 8:27am
YEs Nancy... TERDS ARE THAT IGNORANT.... NONE of the "testing" was done with any HOOD or vent fan...... How to FUDGE the RESULTS you WANT ?????
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 12:04pm
It seems New Holland has developed an ag tractor that runs on methane
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 12:31pm
and all off you die if you have a barbique with real meat
GeneD14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GeneD14 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 1:48pm
I don't believe the proposed gas stove ban has anything to do with health concerns.
It's about control. If they have a rolling brown out or decide to shut the grid down: people with gas stoves still could cook food and eat. They even could warm up a room in freezing temp. People with gas stoves and generators are mucking up the liberals plans.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 6:25pm
  This plan sounds almost absurd as the free crack pipe plan, thank God that got screamed down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 9:02pm
Any IC engine will run on methane, and the earliest, particularly well pumping engines, ran on methane that eminates from the well.  Both of my Fairbanks-Morse ZC-118 and ZC-208 were wellhead-gas runners, albeit they were much newer...
Older wellhead engines used a pretty cool pressure/flow regulator that ran on gravity and water... a inlet tube submerged into water or oil to a depth appropriate for engine's demand regulation- totally gravity operated... incredibly simple, and totally cool.
Now, in many places, much larger engines running on natural gas have been prime movers for irrigation, municipal water, electricity... all the way up to giant gas-blowing engines in the blast furnaces of Bethlehem Steel.  Minneapolis-Moline was a champion at gaseous fuel versions, and if you wanted to 'go big', Waukesha ruled the roost with their massive V10,12,14,16,18, 20, and 24 cylinder machines... they basically ran a diesel bottom end with special heads that lowered CR a smidgen and substituted a spark plug (or sometimes two, or four!) and dedicated coil on each cylinder.  Those Beth gas-blowing engines had something like EIGHT spark plugs on each end of a double-acting cylinder (yeah, they fired in BOTH directions!).  Really wild stuff, and if you go to the National Museum of Industrial History and talk to Mike, you might be able to twist his arm to take you over and show you the big blowing engines... DO IT!!!
Natural gas is primarily methane... and it's 'primarily', because the 'rest' of Natural Gas content is random hydrocarbons (a little propanes, hydrogen sulfide, etc) and some non-flammable gases... it's all stuff that comes from decomposing stuff under the soil.  There's a significant amount of water vapor in there too... and while it ain't particularly strong in comparison to propane, gasoline, diesel or bunker oil,  Any engine will BURN it... just gotta dial back the ignition, push up the compression, and boost the ignition energy by a metric ton.  It's good for around half the unit energy of gasoline... 2/3rds of a unit of propane.
Something that many might not realize, is that most landfills in the US have engines running 24/7 on methane.  They've also got perforated pickup tubes that run down deep into the landfill, and at the top there's big blowers that pull decomposition gasses out of the ground... they're there to help remove the large amounts of trapped flammables, because landfill fires are like coal-mine fires... just a little worse...  but in most cases, they 'extract' enough methane from the 'fill, to feed an engine... that powers the blowers.  Some landfills, and frequently, sewage treatment plants, have 'digesters'... vats that biochemically produce methane for running power units to generate electricity for whatever they can run... so... Powered by Pooh LOL
Deere has been supplying an engine line specifically tailored for CNG fuel, to serve as prime mover in city busses and OTR trucks.  They're much more popular in the city route role, partially because both the running route, and the city infrastructure, are static... same situation every day, and the bus lots are usually not too difficult to get a city gas main big enough to feed a booster pump/chiller unit to get the NG up to liquid state for on-site refuling.  The other reason why they're popular in municipal vehicles, is because that customer base is on the public dole, they can bury the additional fuel infrastructure costs deep into the taxpayer's wallet and make it look 'clean energy'.  It may be less NOW, but two decades ago when the process was developed, the cost of the equivalent effective energy output was roughly 3.5x the delivered cost of buying diesel commercially.
The Deere CNG engines DO run nice though, and I'm certain that every OTHER engine manufacturer has studied not only the green/yellow, but all the M-M, Waukesha, Hercules, and Continental industrials of long ago, to glean out any lessons they could.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2023 at 9:36pm
well,,,ya'll all know,, that electricty comes from that wire that connects to the house,,, right??and,,and milk,cheese, and all that other food comes from the grocery store, right???
no animals were killed in this post....LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2023 at 8:44am
Michael... you been listening to  AOC again ??  LOL
This page was generated in 0.250 seconds.
