Frame width
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: Frame width
    Posted: 08 Jan 2023 at 7:55pm
How wide is a 170/175 frame? I have a weight bracket that I thought was for a 180-200 but after measuring it its 19.5 inches wide. I'm assuming its for a 170/175. Bolt holes are also closer than the bigger tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2023 at 8:06pm
I just installed a 185 weight bracket on my One-Seventy. Bolt holes all the same. Cut it in two on the front. Removed an 1 1/2" of material. Welded a piece of angle iron on the rear of each half at the split point. Bolted it back together, at the angle irons, mounting one side at a time by myself.
