145T
johndiacon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johndiacon Quote  Post ReplyReply Direct Link To This Post Topic: 145T
    Posted: 05 Jan 2023 at 1:05pm
new to forum.  Looking at  145T sn 474 needs bearings and seal for left front tandem axle.  No part numbers at this point, just trying to approx cost of parts. Thanks in advance
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 1:49pm
i have a 145T.  never been into a tandem box but i would guess $500 anyway depending on how big those bearings are.  might get aways with less
Post Options Post Options   Thanks (0) Thanks(0)   Quote johndiacon Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 3:23pm
Do you have parts book,ie part numbers. Owner stated parts are hard to find, bearing needed are “barrel roller bearing”. Any help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 3:37pm
sorry i dont.  the 145 shared a lot of components from the model 45.  the model 45 tandems show what look like standard tapered roller bearings.  minnpar.com has oem manuals you can look at but no 145 parts manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote johndiacon Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 7:28pm
Looked at parts manual for 45 on minnparr, thanks for the heads up. Have to confirm bearing type, but I am interested. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2023 at 6:34am
I have some NOS barrel roller bearings available. I'd need sizes and any bearing numbers (not AC part numbers) to match them.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2023 at 4:06pm
The shop manual diagram of a 45 tandem case is a bit vague but looks like those wheel bearings are likely tapered roller.
Preload is given as 0.00 to 0.010" - would barrel bearings have that?
I had one tandem case centre bearing collapse  and had to re-do that but nothing with the wheel bearings.
Fortunately the local supplier had an ancient paper catalogue which went from Allis part numbers to standard bearing talk.
For the record that bearing is FAG 222/2219 which comes up as
Post Options Post Options   Thanks (0) Thanks(0)   Quote johndiacon Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2023 at 2:43pm
Have been dealing with knee replacement since early Dec.  Thanks for help on 145T.
May have located bearings. Have acquired old bearing pieces. The outer bearing is a link belt series 300  inner race SIS5M90-3, outer SIF5M90-0.   Inner bearing was original failure point, outer race SIF4JA47-0 inner race 263S S4JA,  Inner race broken into 4 pieces with one piece missing.  I think a character (letter/number) is missing between the S’s.
Currently searching for outer seal AC 066860 or interchange also. The missing character may be a one or I. Thanks for your help in advance, have been following the forum for years. First encounter with AC, brand new 1962 “A” Gleaner purchased by my uncles. Pretty big machine for a twelve year old kid!!  Still have it!! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2023 at 5:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2023 at 10:38am
Ive had pretty good luck with www.locateballbearings.com ; for old obscure bearings, races etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2023 at 10:37pm
A local supply firm has an ancient paper copy of an IIRC)
IBR Bearing exchange catalogue
which goes from Allis part number for seals and bearings to current equivalents.  That worked for parts for our AC Forty Five.
I found this on the net -
but it probably costs
This page was generated in 0.266 seconds.
