Calling Pat The Plummer
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Calling Pat The Plummer
    Posted: 05 Jan 2023 at 8:54am
Pat, my favorite throne just leaked water on the floor again.  I want to have a plummer trouble shoot and hopefully fix it permanently.  Looking for a recommendation.  i live between Lake Sangchris and Edinburg.  Would appreciate a recommendation, or maybe you roam this far East.  Thanks
If you can do it maybe PM me your company name, phone No?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 4:07pm
Dave... i think you just need to build an Out House and fix the problem for good ..Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 5:47pm
Steve, I thought about that, but it just would not be the same with the demise of the Sears and Wards catalogs.  Wink
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 9:08pm
Depends where it's leaking. Some leaks are not very hard to fix. Ours here in Florida leaked not very long after we got here this fall. One of the bolts that hold the tank to the stool was not very tight, and my wife bumped it and it started leaking. I drained all the water out and added a little sealant to the rubber washer/gasket and put it back together, the nut firmly. No more leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 9:11pm
Dave... if it continues to leak after you have changed the gasket / seals a couple times.. i wonder if you have a hairline CRACK in the stool ..... bowl or tank ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2023 at 10:45pm
Couldn't be a worse time for me Dave. Covered up with work. Maybe Sunday I could drive over and see what I can do. I will send you a pm
This page was generated in 0.414 seconds.
