R12 0r 134A
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Topic: R12 0r 134A
    Posted: 01 Jan 2023 at 8:48pm
My recent purchase (8070) came from Minnesota (I'm told) and has original R12 fittings on A/C lines. The belt is gone,the R4 compressor turns ok by hand with clutch engaged (not locked) and still has some pressure on system so it's not "broke". Most things this age have been converted to 134 and have the corresponding fittings installed. With the right fittings you can do 134 through R12 fittings. Has a reman R4 but who knows how long ago. (NO HISTORY) What's the chances it is still on R12?  Is there a way to prove it? I still have some around here somewhere. Trying to decide what approach to take. Since this machine will need to be dependable (A/C must not fail!!) I know I should just replace it all and be done Like I did on my other one but if I can make it work why not? LOL! Time you break it apart and flush for new oil and 134 maybe change it all to AP Air and be done. My problem is I like to see if I can make things work. Yeah, I got a few bite marks back there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 8:51pm
In my opinion, a Delco R-4 compressor isn't worth keeping. Remove it. Place it on the open tailgate of your pickup and hope it falls out somewhere it doesn't do any damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 8:56pm
i doubt the put 134 fitting on to charge it, then took them back off.. Once you convert over, you LEAVE it that way......... If it has 12 fittings, i would bet it is R12 system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 9:06pm
Yeah,I know what I should do.....
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 10:04pm
I put the 134 fitting on my M2 and topped off the remaining 12 that was in there. It put frost on the windshield at 90 above. What are you out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 11:17pm
Down side to that is what if it quits in middle of spring season? Too warm in there on a sunny day with no AC. Would have to break out the 220 open station.
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 6:46am
It will work or not right from the start. If it quits blowing cold just add some more. The chances of a catastrophic failure is pretty slim. It probably has a noisy compressor already and that's why the belt is off. Try it in the shop now and see why the belt is off
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 6:51am
134a is not compatible with the oils used in 12 systems, produces a reaction that destroys everything in contact with over time. Entire systems has to be flushed and correct to refrigerant type oil installed.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 2:42pm
The problem now, is that you've got a fixed orfice system (not a TXV) with an incongruent mix of refrigerant at an improper level, where ONE of the two is in a very excessive superheat condition.
This is basically inviting your evaporator coil to become a toxic bomb ready to flood your cab with dichlorodiflouromethane and tetrafluroethane.  About a half-lungfull of that, in a quarter second, and you're out... and trapped in the cab, to asphyxiate.
The biggest investment of servicing an HVAC system, is the time and equipment.  If you want it to work well, and be reliable, just strip the old stuff, mount up a new compressor, new condenser, get a new receiver and filter in, flush the evap coil clean, vacuum the exterior of the coil, get new plumbing in, then pull vacuum, charge the system, leak test it, and then cycle it up.  Once you have it set up right, it'll serve you well, for a long time.  Half-wit it, and it'll be problematic and lame.
Edited by DaveKamp - 02 Jan 2023 at 2:52pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 6:48pm
if the belt is off and you are turning it by hand that just means the clutch is not engaged  i would bet if you energize the the clutch you cant turn that compressor and if you can it is an hour away from burning off another belt
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 8:20pm
With low pressure jumped,the clutch clicks and you can turn it by hand with small effort. Otherwise it just spins freely that's why I say it's not locked up.
ddlong View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 8:49pm
does anyone know what is being used after R134a? I do grocery store, convenience store refrigeration and the long term refrigerants(134a, 404a, 410a, 507, 407a & c among others) are slated to be no longer manufactured like 12, 22 & 502.
I know one of the 1234 refrigerants is being used in vehicles today, just assumed that’s what is being put in ag machinery. And the 134a oil in mobile AC was/is different than stationary AC/refrigeration, PAG(poly alkaline glycol) for mobile, POE(poly oilester oil) for stationary.
Don in IA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 9:05pm
I wouldn't even mess with the old R12. You know what to do already. Change the fittings over to R134A, install a new compressor, vacuum down the system, check for leaks, inspect the hoses and charge it. You can probably pickup one of those Sanden A/C compressors pretty reasonable. Take that R12 compressor and use it for a boat anchor......
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2023 at 9:45pm
Or if it's a sump-type York, use it as an air compressor for an on-board air tank... put a switch on the dash, which sends power to a pressure switch/unloader on a 5 gal tank, then to the clutch...  a guy can always find a use for an air-hose...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2023 at 9:37am
HVAC guy I deal with stated are using a Propane base refrigerant now
Not sure I could trust a flammable gas type even as state is not hazardously flammable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddlong Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2023 at 8:05am
propane & isobutane are being used in residential  and has been for awhile. One commercial manufacturer has been using propane as a refrigerant for close to 10 years.
There are only 3 refrigerants approved for permanent use going forward: Propane/Isobutane, CO2 and Ammonia in stationary equipment. Everything else is bad in some way shape or form according to the “climate change” specialists.
That is why I asked the question of what is happening in Mobil air conditioning going forward. Going from R12 to R134a seems to be only temporary as R134a is on the chopping block too.
Don in IA
