Hd6b hydraulic pump and mount bracket
youngbuck_oldiron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngbuck_oldiron Quote  Post ReplyReply Direct Link To This Post Topic: Hd6b hydraulic pump and mount bracket
    Posted: 31 Dec 2022 at 11:31pm
I am searching for the hydraulic pump and mounting bracket for the '58 hd6b crawler. I've found several pumps that look alike ranging from 960-2200, but the bracket seems to be impossible to find. Anyone know where I can find this! Also needing a generator, but that isn't a top priority.
The hydraulic pump mounts to the from of the buda engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 4:44am
First you have to know what mount you need.  If you are replacing the OEM pump, you can take it off and make measurements.  If you can't find original, you can always dind a pump that fits the specs, and see what mount it uses.  Either way, these guys have a tech page that is very useful, as an intro to pump mounts and other HYD info...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngbuck_oldiron Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2023 at 6:55am
The pump mounted on a u-shaped bracket, I have been scouring to find an image of one but to no avail.
I may end up having to have one fabricated and just find a newer pump with higher part availability.
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 8:53pm
I have a bracket #624120, and coupler (adapter) 625881. I even have a somewhat worn Hydreco pump. My stuff is from HD6G ser 107xx. I'm in Missouri
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngbuck_oldiron Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2023 at 9:22pm
Drcorey, can u send me a photo of your bracket? If this is the correct one I am serious about buying itv
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2023 at 2:35pm
  I don't have a parts manual for your dozer, but the numbers I gave you are HD6G. I'll try to send a photo. I have trouble getting pictures to load on this site. PM me and I'll text them to you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2023 at 8:11pm
   I PM'd you
