WTB 226 high compression pistons |
ACmutt
Topic: WTB 226 high compression pistonsPosted: 14 Dec 2022 at 9:55pm |
Looking for 4 1/8 high compression pistons for a 226. Wonder if anybody makes them? Would like to get compression around 250.
Edited by ACmutt - 14 Dec 2022 at 10:02pm |
DrAllis
Posted: 15 Dec 2022 at 10:18am |
Used to be if you found a set of M & W's from a WC/WD (SP46 kit) they were the ticket. So, if by chance you can get a modern day set of 4 1/8" for a WC/WD and use them with the WD-45 crankshaft, you should have something higher than average. Compression height (piston pin center to piston top) is the key.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4279 |
Posted: 16 Dec 2022 at 9:45am |
I have a set of 4&1/8" flat tops. Comparing them to an M&W, the head of the piston is a little lower but they don't have that massive bowl. I can send pics if you like. I believe they are JCC brand? That is the only marking on them.
Charlie175
Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Posted: 16 Dec 2022 at 11:46am |
These are SK156 Flat top pistons compared to standard D17 spec pistons with wristpin lined up.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
Charlie175
Posted: 16 Dec 2022 at 11:47am |
I have to run 93 octane with those
Charlie
DrAllis
Posted: 16 Dec 2022 at 10:17pm |
Did you ever run a cranking compression test ?? like maybe 200 psi ??
ACmutt
Posted: 17 Dec 2022 at 8:23am |
Thanks, if you could send me a pic that would be good. Do you want to sell them, if so what is the price.
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1019 |
Posted: 17 Dec 2022 at 1:10pm |
should have some used ap46 m&w
ACmutt
Posted: 17 Dec 2022 at 1:54pm |
Steve I would be interested in those. PM me with price? Will you ship?
DrAllis
Posted: 18 Dec 2022 at 3:02pm |
WARNING: SP-46 M & W brand pistons will require removing .150" off the piston tops to avoid hitting the cylinder head !! You measure them to verify this.
ACmutt
Posted: 18 Dec 2022 at 5:28pm |
Thanks for the input Dr, I appreciate your help.
