intake
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Topic: intake
    Posted: 07 Dec 2022 at 6:33pm
Gentlemen,
I am having 2 problems with the intake system on my tractor: 1) Icing , to the point if conditions are right, it will stall the motor under a load.   #2) no room to put the intake in the warm air from the motor. Are commercial filters the only way to go, or could I make my own filter system to accomodate the space available in the warm air stream.
I am looking for opinions and experience in this area. What works for yall?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2022 at 6:53pm
Kind of hard to advise, not knowing what brand/model of tractor. Make a tin shield that covers the intake AND EXHAUST manifold all in one to make exhaust manifold heat work towards the intake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2022 at 8:25pm
 Dgerth; Easy enough for you to make a heat shield around the G160 engine's manifold like I did for the engine in my CA, patterned after the OEM kerosene shield. This fits tight around the manifold, No more problems. This only became an issue after I switched form expensive racing gas to cheap E85,even with the richer jetting needed. I found a considerable increase of power with the E85. I also now use a 180 degree thermostat. Any cold engine/manifold will not properly vaporize liquid fuel. That is why propane engines have a water heated fuel vaporizer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2022 at 5:29am
Sorry, should have put this in. It's a CA and I'm running 14:1 CR and a large Zenith carb. E85 is nonexistant in my area so that option is sorta out. I'm using 120 race gas at the moment so I guess a heater of some sort is in line. Any thoughts concerning the air filter dilemma?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2022 at 8:58pm
Add some methanol to your fuel.              MACK
