WC Value
BH Reinen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BH Reinen Quote  Post ReplyReply Direct Link To This Post Topic: WC Value
    Posted: 08 Oct 2010 at 3:16pm
What is a WC worth top value? Fresh engine all new rubber Thanks Bart
Andrew Kimbrough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 3:43pm
Bart,  is it styled or unstyled?  If you post a picture someone could probably help you out better
AaronB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 6:30pm
$1500-2500 tops depending on overall condition.  Features such as factory w/f, front steel wheels or stamped steel rearend(wartime model) will be worth more.  Most WC's around here go for $700-1200 in unrestored condition.
aaron
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 7:14pm
Most WC's around here go for $500 to $700 in solid running condition. With new rubber add $600 and an excellent paint job you can add from $300 to $500. There you have it, a $1500 tractor. If it is unstyled and correct you can add a little more.
Larry Swensons book says mid range condition $1025, next step up $2625 and top step being absolute perfect condition $2875. His prices may be a little optimistic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 9:01pm
And I was given a 35WC that was pretty much complete and I'm afraid to think what I will have in it. I have $5 in used front tires and $0 in take offs(14.9-24's) from steer wheels on a JD combine. I would guess the final tally would be somewhere near $3500<or>.
