Dimmer light question for electricians |
iowallis
Joined: 04 Jun 2017 Location: North Iowa Points: 387 |
Topic: Dimmer light question for electriciansPosted: 27 Nov 2022 at 10:29am |
Living room ceiling fan/light combo. 2 entrances to the room. By one entrance is 2 switches, one for light, one for fan. Other entrance has a toggle switch dimmer with the slide right next to the switch. House was built about 12 years ago and fan/light was installed then, problem started maybe 5 years ago.
Turn on the light (either switch) with the dimmer on full light and the light will be full brightness for anywhere from 30 seconds to 5 minutes then drop down to 1/2 brightness. Dimmer switch will go from full bright to almost off as designed but when the light goes to 1/2 brightness doesn't matter if I move the dimmer down and back all the way up it still stays 1/2 bright down to almost off. Turn the light off and turn it back on and same thing, bright light for a random amount of time before going to 1/2 brightness. With us having Christmas this year my wife wanted it fixed. Thinking the dimmer switch went bad I replaced it today with a Lutron brand switch which was the brand of the old switch. Didn't fix it. Any ideas on what to check that I, a somewhat handy homeowner, could check? Something else odd is that with the other 2-way switches in our house with the light on one switch will be "off" and one will be "on". With this light both switches are in the same position with the light on, different positions with the light off.
Edited by iowallis - 27 Nov 2022 at 10:40am |
Grayray
Joined: 12 Sep 2009 Location: Ambridge PA Points: 3860 |
Posted: 27 Nov 2022 at 11:13am |
When your problem started about five years ago, did you happen to change the light bulb from an old-style incandescent bulb to a fluorescent bulb or LED bulb? Some of these bulbs are not compatible with dimmers. If so, try changing the bulb to one that is compatible.
iowallis
Posted: 27 Nov 2022 at 12:01pm |
Still has incandescent bulbs.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35684 |
Posted: 27 Nov 2022 at 12:13pm |
Sounds as switch is bad, replace it before the magic smoke releases and alights the remainder of the house.
iowallis
Posted: 27 Nov 2022 at 12:36pm |
New switch was installed, same problem.
bigal121892
Posted: 27 Nov 2022 at 4:52pm |
If replacing parts doesn't work, then my guess would be a loose connection somewhere in the circuit, as it heats up the resistance goes up, which cuts back voltage on the triac, (electronic device that allows the light to dim). I would start by checking the neutrals, then the hots.
Edited by bigal121892 - 27 Nov 2022 at 4:53pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55288 |
Posted: 27 Nov 2022 at 5:28pm |
Check by the fan, as that's where the vibration is...
bigal121892
Posted: 27 Nov 2022 at 6:21pm |
Usually the fan is wire nutted, as a general rule I don't see those coming loose, (provided the correct wire nut was used). Screws on the other hand, as the wire gets hot and cools over time, will allow the wire to move, and work their way out of being tight.
DaveKamp
Posted: 28 Nov 2022 at 8:56am |
Al and Dave have it right- Half-voltage is usually the result of an open neutral between two circuits that 'share'... instead of a parallel circuit, the lack of neutral makes it a series circuit, so voltage is split between the two. ANY connection, particularly in immediate vicinity of the fan, will be susceptible to vibration... and as a resistive connection warms up, it eventually reaches a point where it limits out it's abilities to carry current.
