D17 backhoe
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Topic: D17 backhoe
    Posted: 27 Nov 2022 at 7:20am
How much does a d17 back away? Looking at buying one about 3 hours away and need to know if my trailer is heavy enough. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 5:23pm
Unsure of the question you are asking.  The whole tractor (without ballast or loader) weighs about 4600 lbs.  Do you want the weight of the hoe? or it plus the tractor and loader?  HTH...Wink
Edited by DiyDave - 27 Nov 2022 at 5:25pm
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 9:35pm
Sorry. Yes, meant weight of tractor with backhoe attached. If it makes a difference, it is a gas tractor not diesel.
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 4:09am
I'm gussing, here 8500-1000 lbs...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 8:16am
Pretty small picture, but are you sure it's not a D-15 ??  Weight won't be much less regardless.
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 11:10am
Did they make a d15 series 2 with backhoe? In some of the pics on his post you can see a dry air cleaner and belt power steering pump. Looks like my d17 series 3.
elec View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elec Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 11:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 1:39pm
YES. D-17 it is. I didn't know they made a D-17 like that and yes, they did make D-15's in that configuration.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2022 at 8:38pm
According to my brochures, the tractor weighs 5300 pounds and the loader and backhoe together weigh 4372 pounds.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2022 at 9:32pm
I bought a new towable back-hoe, it's rather small but a lot less than a worn-out one on a worn out tractor. It is rather small but it does what I need. If I remember right it has a 13" bucket and digs 4ft deep.
This page was generated in 0.262 seconds.
