D17 series1 brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: D17 series1 brakes
    Posted: 26 Nov 2022 at 4:46pm
Finally started a job that I’ve been dreading since I bought the ole girl. I knew the brakes were bad on the right side when I bought it this year which factored into my offer for it. So I soaked the pins from the bottom access hole Kroil about a week ago. Had my local machine shop make a puller like the ones you can buy but out of heavier steel. I couldn’t believe it but I hardly had to wrench it before being able to pull it out. Pulled the brakes and verified the damaged to the drum. It will have to be replaced on the right side. Will replace seals while I’m in there. The left side pin also seams to move easily although I didn’t finish pulling it because I need 1 one good brake to put her on my trailer to take it to my buddy’s shop so I can use his overhead hoist to remove the drop housing. Left side axle seal and pinion seal is leaking so that side has to come off as well. Fun, fun
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 6:53am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 7:23am
You're way ahead of the game just having the pins out! My success rate with the puller is probably around 30%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 1:03pm
I’ve heard lots of stories about the pins being rusted in place, heads breaking off while pulling. I firmly believe the Kroil did its job, it’s been a great product for me for a long time. The right side brakes haven’t been touched for a long time as the picture shows the damage from neglect. I did take a long punch and tap the pin for about 10 hits hoping to loosen it. Not sure if that helped but they came loose easily. I’m really dreading the next step to get to the drum.
Edited by AC720Man - 27 Nov 2022 at 1:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 9:53pm
Getting to it may not be your worst job...it may be removing and installing the drums.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 8:13am
Are you going to do the diff seals while you are in there? Save doing it again in a year or two.
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 9:27am
your answer is in first post
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 2:07pm
Thanks Steve. Lol. What a dummy. My excuse is I am working with one eye - just had retina surgery! SmileSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 2:23pm
I have heard they are a bear to get off Steve. A few resorted to a torch after the puller failed. Hoping I won’t have to do that. My old AC dealer has a puller that he is going to let me borrow. I watched a YouTube video with a guy using a hydraulic puller. That looked sweet but no way I want to spend that kind of cash for one. Maybe I should put some Kroil on it for a few days.
Edited by AC720Man - 28 Nov 2022 at 2:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 3:26pm
BRAKE DRUM REMOVAL: Step #1. Take a 3 or 4 pound hammer and break the drum off the center hub one piece at a time !!  Be careful and watch out for flying cast iron !!     Step #2.  Rest what's left of the brake drums hub on a solid stand. Take a large sharp chisel and with the hammer used in step #1, split the hub right at the keyway. The hub will virtually fall off. Step #3. Place all tooling back where they belong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 3:44pm
Thanks Doc, that sounds like a good plan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 8:45pm
After busting drum off, use a grinder with a cut off disc to slot hub over keywey to key, then use hammer and chisel like Dr. said. Will save a few licks with hammer.                 MACK
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2022 at 5:15am
Off topic, but thank God we have guys like DrAllis and Mack (and a bunch of others) that make very hard jobs, easier with the knowledge they so willingly share with us "rookies".
Thanks to you guys !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2022 at 6:40pm
That’s for sure
