OT hammermill
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: OT hammermill
    Posted: 26 Nov 2022 at 2:54pm
Ok I picked up this hammermill, local, cheap price, and probably a pig in the poke.  Cant identify it.  Notice the hammers dont "flop" - are fixed - the lettering looks like a "N" and a weird "E" and a small number "42"  Nothing I have found on the web matches close enough.  I wonder if this was some local thing.  The big casing over the hammer is welded together...weird....
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2022 at 6:53pm
Its a Case!
One of the H series....
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 12:51am
I've never seen one like that. Then again, most around here were W-W Grinders, built in Kansas I think?
I believe the reason for the hammers not moving is because when the hammer gets worn, you loosen the bolt and rotate the hammer 1/4 turn and tighten back up to get a new edge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2022 at 4:32am
And flip them hammers over and you have 8 edges!Thumbs Up
This page was generated in 0.054 seconds.
