WD Rear end lube
hotrodpierre View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodpierre Quote  Post ReplyReply Direct Link To This Post Topic: WD Rear end lube
    Posted: 07 Oct 2010 at 8:42pm
Hi guys,
I asked about this on another forum, but I wanted to make sure i was on the right path, so i am checking with you. Plan on changing rear fluids in the WD this weekend. I am told there are 3 drain plugs. I also see two fill plugs, one closer to the starter and one closer to the shifter behind the battery box. Do they both go to the same place? I was also told 18 quarts when all is said and done. Does this sound right and is there anything else I should know?
Thanks,
Jake
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:05pm
There should be 3 fill plugs on the left side.
The front 1 is for the hydraulics, the middle 1 fills the hand clutch and rear end, the back 1 fill the rear end and the hand clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodpierre Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:22pm
I saw the the one for the hydraulics, so the other two go to the same spot then? Does it matter which one I fill up?
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:25pm
the rear one is for the transmission and the rear and takes 80-90. The hydralics and the hand clutch take Hydra-trans. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:26pm
Fill them both full.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodpierre Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:28pm
interesting. How much do I put in each one? Sorry for being an idiot, but I dont have manual yet. i would not have guessed from previous info that the hand clutch was supposed to have hydratrans. I was told the rear takes 18 quarts, is that right? if so, how much do I put in the front one for the hand clutch?
Thanks for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:29pm
Only the front one (dipstick) takes hy-tran....the other two take 80-90 and share the oil between them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotrodpierre Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 9:34pm
Good, that is what I needed clarification on. Thanks!
