190XT front tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 190XT front tires
    Posted: 21 Nov 2022 at 10:43pm
I have tried doing a search with no luck. Maybe I am doing it wrong. I presently have 7.50x16 wheel tire combo up front. I want to switch to a wider tire/rim. 10.00-16 or a 11L-15. Tire isn’t the issue, it’s the rim offset that I’m wanting to verify. I think the 200 had this rim. Just don’t want to order the wrong rim. Any help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 6:43am
200's usually had a 9.5 L x 15. This was an attempt to offset the dropped front axle because of the new crankshaft driven oil pump bulge in the oil pan.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 7:58am
the 200 i bought recently had 10.00X16 fronts, and needed new tires, rims too, so I bought new 11LX15 tires and rims from our local tire shop. The rims were already close enough cream color for me, and they are on 8" wide wheels so they aren't really short and squatty like 11L usually are. These look really good on it, it has 34 rears. The center is offset a couple of inches, so will only fit mine one way, and tire is about an inch and a half away from spindle upright.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 10:55am
Rims off a New Holland round baler like a 851 should work they are as heavy made as any front tractor rims,running them on the front of 2 loader tractors.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 1:20pm
Hmm, it sounds like you have 7-16 rims so I’d think you’d be able to get like 9.5-16 or 10.00-16 on the same rim…
I could be over thinking but on a ji case I have, the tire shop said 9.5-16s would go right on the 7.5-16 rim with no problem.
1955 AC WD45 diesel with D262 repower, 1949 AC WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 3:14pm
I presently have 7.50-16’s. Ed, the rims usually have the size stamped into the rim. Would you mind looking for me? Offset is the killer so as not to rub the knee. If you have time send me a picture. Hopefully you still have my number.
I have only about an 1” clearance of the factory wheel tire combo. I would think a wider tire of the factory rim will be too much but what do I know? That’s why I’m asking
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 5:30pm
Allis55:  a 9.5 or 10.00 x 16 tire will NOT fit on a rim that had 7.50 x 16s - the rim would be way too narrow for tires that wide.
My 190XT had 7.50 x 16s when I bought it.  I got a set of 10.00 x 16 tires and rims from a 200 and they fit perfectly.  No rubbing on the knee.  If you order a rim for a 200, you should not have any problems.
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 5:56pm
Dad bought our Series III XT new. It came with 10.00x16 tires from the factory.
From Agco partsbook  Rim for 10.00x16 tires; 70257789
Sorry it doesn't have the offset information.
I could go out and try to measure ours but I don't think I could be real accurate with them mounted on the tractor.
Steve
Edit, Kind of pricey from Agco at $220 each.
Edited by SLee(IA) - 22 Nov 2022 at 7:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 7:10pm
Appreciate everyone’s input. Steve that is the same part number I got from Agco. I wanted to search some wheel company sites but I need the offset. I was quoted $255 from Agco today. Just wanted to do some price searching.
Myron, that’s the look I am looking for. Nice looking series 1.
Edited by AC720Man - 22 Nov 2022 at 7:13pm
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 7:46pm
720 man, make sure you get tractor rims, not implement rims. Tractor rims have a far heavier center in them than implement rims. They are made to take the stress of a loader or stress of turning. Wagon/implement rims are made to roll straight with very little of the turning stress. A salvage lot might be your best bet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 8:04pm
Absolutely, was only searching for tractor rims.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 8:31pm
call agwheelexpress.com. They will get you set up
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 10:02pm
I replaced the worn out 9.5Lx15" on my AC200 with a set of 10:00x16" on rims that came off a IHC 856 or 1256 tractor w/factory WF. The offset is correct, less than 1/4" change in distance of tire to knee/spindle. Made it ride nicer doing field work.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 9:15am
I'm going to dispute this a little, just a little. My 756 has 10.00x16's on what I assume are the factory rims. It would have had 6.50x16's originally. They don't look bad, but not quite right either. I have no plans of changing them... The 185 has 11L15's on, I believe IH rims. They were on a 966 is the info I got at the sale. Fit, work. and look great to me.
[/QUOTE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 1:55pm
Allis55:
[/QUOTE]
Hmm
I’m starting to need to look for a new set on my wd which currently has 6.50-16s, so I’d like oversized fronts because I have 16.9-28s on the back…
I wonder if I could get a 7.50 or a 9.5-16 on the same rim?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 4:18pm
9.5's are 15's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 6:11pm
7.50-16 tire will fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2022 at 9:10pm
Mike, They've been on it almost 10 years, no issues except tires starting to weather crack. Carries the loader a lot nicer in soft dirt than 9.5Lx15 did.
 The tires and rims were found in a friends in-laws machine shed, while getting ready for estate auction. My pay for a days work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 6:28am
Put some of the rims both implement and tractor on a scale to see which weighs the most,in other words has the most metal in them and you'll find out what you say isn't always true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2022 at 10:29pm
Found some rims from a 200 today, has worn out tires on them but it allowed me to see how they fit. Just need to sand blast, paint, and install new tires. 11L-15. Will save me about $250 going with used rims.
Edited by AC720Man - 25 Nov 2022 at 10:38pm
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2022 at 8:58pm
What i have done is buy blank rims and centers from Miller tire and weld them in with the offset you need, their centers are heavy duty  and look just like the original wheels, this way you won't have to use an implement wheel and reverse it to make it fit, that just doesn't look original.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 1:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 1:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 1:21pm
The sideways picture problem is back ugh. Anyway, I finally got my tires and wheels on today. Will have to wait until spring time to touch up the paint. Very happy, 11L-15 Carlisle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 1:36pm
I straightened them out for you ac720man…
And they look really nice!!!
Edited by 55allis - 12 Dec 2022 at 1:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 3:46pm
Thank you 55allis, appreciate the compliment and straightening out my pictures
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 5:10pm
That is one very nice looking XT. If I live long enough, we have a 72 bought new, that someday.....will be restorded.
Leon B MO
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 7:26pm
yours look like they are on 10" wheels, which makes them wider. Mine are on 8" wheels and they look almost like a 9.5L lol! Mine looks a lot like the bar grill xt pictured above. Funny how a rim difference can make a huge difference in the tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2022 at 8:03pm
Good eye Ed, they are in fact 10” rims. Oddly, they are just about the same height as my 7.50-16’s. I couldn’t be happier with how they look. I was glad I got the Carlisle, made in the USA which surprised me.
