WD45 part out. questions/history
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 part out. questions/history
    Posted: 20 Nov 2022 at 7:16am
I found this tractor close by and thought maybe I could save it. The engine sat to long with water in it, One rear rim is really rusted and bearings in the right final where shot. So the best solution is parts. Many questions about what this tractor did and repairs that were made. The tractor was never repainted, very few new parts and not much rust. It has cultivator brackets, worn spots on the frame from a loader and extra holes in the frame. The pistons and liners had been replaced with oversized. The crankshaft had new standard bearings. The clutch was new with a 9 spring pressure plate. The PTO still had the factory shear bolt. The hand clutch is completely new. The shifter lever has lots of movement side to side. Third and forth gear had wear. I suspect power shifting. Only one spring was missing from the tractor. All the others were still on the tractor and in very good condition. Including quadrant and brakes. The draw bar had no welds, bends, or brakes, but was missing the snap coupler release lever and chain. The hook in the bell had very little wear. The lift latches wear never off. Has an after market seat. I think a joy rider. The lights were not rusted, broken, or bent. Hydraulic hoses and lift cylinders were fitted with quick couplers.  I think a well cared for but a little rough use tractor.
1
http://lonsallischalmers.com
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 7:24am
Interesting story. Is it possible it blew the head gasket and got parked? Sounds like it had good care for most of it's existence. Maybe the owner passed away and it got ignored for several years?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 7:34am
Antifreeze was to the top of the radiator, the radiator had been repaired. The head gasket was fine and was an aftermarket gasket. Water started coming out when I took the manifold off. The fellow I bought it from left it outside. He bought from someone else for $800 and it was running then.
Edited by Lon(MN) - 20 Nov 2022 at 7:36am
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 7:54am
Got a pic of the Joy Rider?
Learning AC...slowly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 8:24am
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 8:40am
So what is the ? part or sell and get money back .
nonetheless ,still dead.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 9:45am
Could have been parked because of the R/H Final Drive Bearing issue.
Final Drive Brgs. are common between WD and WD-45.
Get a Final Drive from a WD donor, then start on the engine.
G
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 12:21pm
Sometimes they start out as a one owner unit that was babied by the original purchaser. Then, the original owner dies, retires or ends up in a nursing home and it falls into less caring hands, maybe even a few different owners. Depending on how the consecutive owners used it, there may be nice parts still from the first owner and worn out parts from the abusive later owners. Sadly, not all cream puffs fall into caring hands as time goes on. This happened with my uncles 2 A-C's.  Got one of them back years later but it wasn't in the shape uncle had left it. Never found the other one, maybe for the best.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 3:13pm
Originally posted by Lon(MN) Lon(MN) wrote:
Thank you. Does it set back further than the stock seat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 5:16pm
I am much better with a wrench then writing.
Fred, I was questioning what the history is on the tractor based on what I found as I took it apart.
The seat does not set back any farther.
The tractor is all apart and on the shelf now.
The pistons are 4 inch diameter that have a dish in them. They are as tall as a WD piston measured from the wrist pin. Did any engines come this way from the factory?
Thanks for the response.
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 4:40pm
4" bore with a dish in them sounds like the factory power crater pistons for a WD45.   Overbores are traditionally a 4 1/8".
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 6:04am
These pistons are dished like the aftermarket 4-1/8. This is the first time I have seen 4 inch pistons dished like that.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 5:33pm
I thought all these 226 gas engines in the WD45 were dished pistons. Thus the name power crater engine. Smile
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 6:20pm
The determining factor regarding 4" pistons is if the dish has a flat bottom or curved bottom?
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 6:42pm
Thanks Alex. So did they come both ways? And what was the application for each?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 7:24pm
WD-45 Power Crater pistons had a smooth curved bowl and were 6.5 to 1 compression. D-17 are a flat bottom bowl and are 7.25 to 1 compression. Look in the knowledge section for pictures.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2022 at 9:25pm
Thanks so much Doc. I just looked there and saw all the pics. One picture is worth 1000 words. Sure clarifies that. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 9:20am
Ed, 65 years have passed since the last 45 came off the line. Only way to know what pistons are in one is to pull the head and have a look! Lots of changes over the years!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 10:06am
Oh yeah! I fully realize that Mike. LOL. I don't even know for sure what is in mine because it had a rebuild at local machine ship. But from the factory they would have been one design or one design and maybe an update? SmileSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 6:25pm
So the question is are there any of those dished flat bottom pistons and sleeve kits available now? 7.25 ratio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2022 at 9:52am
I found one new set 10 years ago. I found two sets in parts tractors. Never know what you will find when the tractor is no longer used or a new owner picks up an Alice chambers with fenders and two point cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2022 at 11:36am
I have several new old stock 4" bore 7.25:1 ratio D17 pistons in stock here. The harder item to find is the 4" sleeves.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2022 at 12:17pm
I just so happen to have a good used set of 4" sleeves.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2022 at 3:24pm
Actually, I got a cheap USB borescope/endoscopy-type camera that will look right down a spark plug hole handy-as-can-be... it'll reveal all sorts of fantastic stuff without pullin' that head!  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2022 at 5:33pm
I have boroscope as well. Should peak in mine one day and see. Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2022 at 6:07pm
Dave, I thought about mentioning that but you can't measure bore diameter so that's why I posted what I did. Would be easy to see if you have M&W's with one! Heck, you might be able to pull a plug and see them with a flashlight.
