Track chains for an AC 7G-B?
Bill7GB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill7GB Quote  Post ReplyReply Direct Link To This Post Topic: Track chains for an AC 7G-B?
    Posted: 19 Nov 2022 at 8:48pm
I'm looking for a new set of track chains or a decent used set. Any help would be greatly appreciated.
Thanks,
Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 9:13pm
Might try Thill Track and Tractor in Eau Clare WI
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 5:45am
Are 7” pitch, only two manufacturers ever used, Allis and IH, none exist new in USA and are as scarce as hens teeth as used.
I looked for months, finally found a 7G tractor that was derelict that had decent rails, it left here over two years ago to Davenport IA and was destroyed by new owner. Likely went to scrap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 6:24am
Will add this, your G-b has segmented sprockets, IF can locate one that had Cat 6.906 Rails installed in the past and segments are still good can swap to that pitch.  Cat in the late 80s offered Segments for the Allis Sprocket Centers, they do not any longer and I do not have their p/n.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 7:38am
As to my old 7G
Tom Stutting of Commanche Ia bought it in Sept of 2020, he was dealing with memory issues then, later that year he developed full onset dementia and died April 2021.
The 7G was never repaired, no one I talked to after his passing knew where it went except his kids had it hauled off along with all the remnant parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 8:03am
Alright, so I took a chance, in Nov of 2021(Google Maps) the machine was still sitting at 417 S Washington in Commanche IA.  May want to look into that as had 90% life rails on it.  Is also a 4/1 and a rebuilt GP bucket for that machine, same mounting as yours.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 9:17am
His 4 sons are all listed in his obituary.
https://obituaries.clintonherald.com/obituary/thomas-stutting-sr-1082098007
Edited by Gary - 20 Nov 2022 at 9:49am
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2022 at 4:33am
Very easy to get upside down in the old tractors but if you are willing to expend the $$$ your undercarriage can be rebuilt; with some limitations. I have laid the groundwork to do exactly that for the undercarriage size you have.
If interested you can PM me on this site and we can discuss, but it would be less expensive if you could find a used u/c. As mentioned they are getting scarce.
Thanks,
