snow
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Topic: snow
    Posted: 18 Nov 2022 at 5:42pm
sounds like New York is getting pounded with snow.  3-4 feet already and maybe a couple more feet coming tonight.. West wind blowing over the Great Lakes carrying it in... Be careful up there !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 6:07pm
BooFoolow is getting POUNDED with Pretty, at least is NOT here.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 7:00pm
Grand Rapids and Kalamazoo got 15 inches and more coming.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 7:22pm
you guys are lucky
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 7:40pm
Gotta' watch that Lake effect snow! It seeks up on ya!!   Yikes!
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 6:51am
Not sure about lucky. 66 inches out by the wife's family. Said it was coming down 5 inches an hour with thunder and lightning. Newer a good sign when Jim Cantoree is reporting from outside your house
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 6:58am
WOW!!
Thunder Snow!!
Shamers sure tuned that beast machine up with his fresh cash load!!
Blowing pretty across the lakes making it ever worse!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 11:02am
Only got a few inches here in eastern MN but the dang cold has set in now .
Son is just finishing up his order to dealer of 25 plows and seems dealer now wants another 10 plows as has got a bunch of orders for different mounting types .
 Most of plows were made for compact and small utility tractors but a couple skid loaders also .
 I plowed the church next door the other nignt , not a lot of snow but got it cleaned off with the pickup truck plow .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 11:45am
My 665 Skid with one of sons new plows he just completed and delivered . Special order as it has 2' wings added to blade . Ordered for clearing snow from appartment complex , to use as both pusher and a plow . https://www.facebook.com/profile.php?id=100063760264642
Edited by Coke-in-MN - 19 Nov 2022 at 2:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 1:28pm
Painting them the right color, looks good Coke . Did your son give Shameless a deal on that tree puller ? Sounds like they worked out a deal , all the snow Shameless can make means more snow plow sales .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 2:55pm
He has several different colors he paints units in - all the back frames are painted black but blades come in several colors . One thig is he designedthe plows with a single hydraulic cylinder for turn system rather than 2 rams , and every plow has a relief valve installed so if something is hit it wont blow a cylinder or damage the plow .
  Unsure what deal they worked out - but know he was liking the unit for what it did .
I delivered 2 plows a while back - one to Indiana and other to Ohio for son.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 3:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 3:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 5:39pm
Those are really nice units Coke! Yes darn nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 9:23pm
The green plow is for John Deer and has the double mounting pins on bottom of face plate , the light and smaller Compacts have one set of pin locations and the larger units use pins in different place so he makes them accordingly .
 That unit is going to a dealer and was built so it fite either loader face plate .
He uses the single cylinder to shorten the distance plow is in front of machine , If you have seen the A frame used on many units it puts plow about 2' further out from front of machine ( like a truck mounted plow )
  Plow come with 4, 5, 6  web backers on plow blade and also 2 different weights of the frame . Notice the 3rd link on top which is pinned for down pressure or pin removed to float plow . Also the design allows the plow to stay parallel to surface when angleing plow as there is some foat in the overall geometry .
Edited by Coke-in-MN - 19 Nov 2022 at 9:31pm
