Wax toilet ring ?s
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Topic: Wax toilet ring ?s
    Posted: 18 Nov 2022 at 2:00pm
I have a question for the plumbers! I've had trouble with the wax rings on a couple toilets in our house ever since I've lived here. Seems they last a year or two, then one day...your socks get wet. Maybe I'm doing something wrong. Flanges are level with floor. Toilets don't rock on the floor. Bolts are tight keeping the toilet from sliding. Toilet is centered over flange. I've tried the rings with the plastic insert, tried the ones without, tried using two rings... nothing seems to last. I was doing some reading on toilets and a few people recommend the wax free, rubber or silicone toilet sealing rings. Do these work better than the wax?? What's the plumbers opinions?
Thanks!!!
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 4:38pm
First, check to make sure the flange coming up from the floor is at the correct height, and check if the flange moves.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 4:39pm
My first answer would have been be sure toilet isn't rocking on the floor. This is BEFORE setting a wax and tightening bolts. Once I have confirmed it does not rock either on it's own or shimmed accordingly, I set a wax then carefully set the fixture and then snug up the bolts. Have rarely used the type with the plastic horn. I would massage the ring so it would center on the flange surface and make it taller. If the flange is flush with the finished floor I would mold 2 together in that manner. Is the flange secured soundly to the floor? Is the flange out of shape due to age? Check the bottom of the toilet to ensure all old residue is removed and dry. On occasion if the glazing underneath was on the sealing area, I would smear a little fresh wax on the area to give the ring something to seal with. Perhaps a little over the top for some but I had very few call backs with that method over 20 years. One client I had was in a feeble condition and put a lot of side pressure using the commode so I had to resort to a seal with a rubber ring that stretched over the horn and another adjustable o ring down the pipe. Never had to reset it again. Have never used the rubber/foam rings. May be worth a try if the above method doesn't work for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2022 at 4:50pm
Not a plumber, but i have installed several.. I ALWAYS take some extra wax ( old ring or ???) and SMEAR it on the bottom of the toilet and a thin layer on the drain flange.. Then i set the way ring and allow it to  mash into the SMEAR area.........if the toilet does not ROCK , it will be very hard for it to start leaking.
Edited by steve(ill) - 18 Nov 2022 at 4:51pm
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 8:08am
Uhh, not a "plummer" but am aware that different thicknesses of rings are available.  I set my last two using the extra thick rings.  Confused  That was after an additional 1/8 inch vinyl floor was added.  And since I am old as dirt and my back gives me fits, I took the back tank off before install to give me more control in setting the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 10:56am
I would inspect the sub-floor for movement or for give when compressed by fixture , as if it gives it could allow the wax to be compressed then allowing a gap to form after weight is removed - have had some where wax got off and partially blocked flange and allowed leakage .
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 12:44pm
That's why I mold them to fit. Out of the box they tend to be smaller diameter than flange. Too much hangs over the pipe inside diameter for my liking
Post Options Post Options   Thanks (1) Thanks(1)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2022 at 12:59pm
Flange is supposed to be sitting on top of finished floor, not flush with it . Supposed to only be 1/4" or less gap between bottom of toilet and top of toilet flange. Bottom of toilet has a "horn" which sits inside flange. In theory shouldn't leak without a wax ring. Wax seal is for odor and keep from splashing out . Wax seal is not a pipe. Menards, Lowe's sell a toilet flange extension. Yellow plastic piece that fits tightly inside and over existing flange. Kit has several different sized spacers but you won't need them.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 1:38am
I've used the red wax free rubber rings on a couple toilets I'd never use another wax one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2022 at 8:12am
Dang Pat, thanks  for the post.  I learned something there.  Hopefully I won't need to apply it.  Confused
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2022 at 12:49am
  Many Thanks to Plummerscarin and Pat the Plummer for this info which is very helpful,,,THANKS GUYS,,!!!!!Clap
Gerry D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerry D17 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2022 at 1:02pm
Hi I had a problem with a wet floor and thought it was the wax and changed it out twice and in the end it was the gasket between the tank and bowl that had a small leak. Just a thought.pain in the ass changing the wax for nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2022 at 3:43pm
Either one is a pain. To sum it up, verify the source of the leak then proceed
