serial #
stuck in the mud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stuck in the mud Quote  Post ReplyReply Direct Link To This Post Topic: serial #
    Posted: 07 Oct 2010 at 2:02pm
Hi I am new to farming and recently bought an A/C D-17 and I am wondering where do I find the serial #. I found a feq #'s does it start with a letter or # and should it be 6 digits. I am trying to find a disc it came with a plow had some fun with that but now I need more also on the right side I say that as I am sitting on it there is a round flat pulley which would accomadate a flat belt if I took that off is there a plate that would cover the hole and is that part worth anything, Thanks there is so much to learn about.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 2:05pm
Here ya go!  On the left side when sitting on the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 2:14pm
The tractor serial number would be stamped on the left side front torque tube  flange .http://people.clemson.edu/~wsmth/SNLocat/ACSN5.htm
Serial numbers from here on are the beggining number for each year
D-10 - - - - - - - - - 1001
D-12 - - - - - - - - - 1001
D-14 - - - - - - - 1001 9400 14900
D-17 - - - - - - - - 4300 16500
** WD-45 production began at 146607 in 1953
1960's
Model 1960 1961 1962 1963 1964 1965 1966 1967 1968 1969
D-10 1950 2801 4511 6801 7675 8204 9486 9795 - -
D-12 1950 2801 3638 5501 6012 9192 9508 9830 - -
D-14 21800 - - - - - - - - -
D-15 1001 1900 6470 13001 16928 19681 21375 23734 - -
D-17 28200 33100 38070 65001 70611 77090 80533 86061 -
Yes the belt pulley is worth something to a lot of people. There are delete plates around for the pulley but if you can't find one it would be very easy to make one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stuck in the mud Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 3:04pm
Thanks again and I will learn with your help and my mistakes but thanks
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 3:19pm
Where about in west Michigan are you? I am from the Fremont area. There are a couple salvage yards around me that may have parts if you need them.
Brian
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 3:28pm
NE Michigan here......
1968 D15D,1962 D19D
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2010 at 6:32pm
I have a feeling that there are more guys on from Michigan than any where else.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote stuck in the mud Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 4:28am
I am by Burnips. S.E. of Holland a little
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2010 at 7:21am
I'm over south of Fenton, between Detroit and Flint!   If my wife had her way, we would be living on the west side real close to a beach!
Speaking of MI and surounding areas,  I recently heard the Great Lakes referred to as "The Third Coast"!  Thought that was an interesting thought!
