7000 vs 8000 |
GWS
Joined: 13 Nov 2012 Location: Central NY Points: 269 |
Topic: 7000 vs 8000Posted: 05 Nov 2022 at 8:34am |
I loved my 7030, but it did have one little annoying problem. When I was trying to turn in a tight space at low rpms (backing something carefully into a shed), it was difficult to steer. I'd have to push the clutch in and fight the wheel, or bump up the rpms. I know a lot of older tractors do this.
Was this corrected in the 8000 series? Thanks, George
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 05 Nov 2022 at 8:46am |
That part is same between them...I'd say your hyd system was not up to spec.
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 05 Nov 2022 at 1:09pm |
sounds like one of several possibilities, worn pump, low fluid, plugged filter, contaminated fluid, sticky valve
