B exhaust
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: B exhaust
    Posted: 30 Oct 2022 at 7:27pm
Can a exhaust be welded broke a front piece?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 8:37pm
you can try... Cast iron does not weld good to start with... when its 70 years old you have a lot of carbon and not much iron left.... I have repair the front or rear EARS on a couple with some luck.... Not much luck with cracks / rust out in the center port areas.
clean it real good... then clean it again...grind a bevel on both parts.. clamp them together in alignment.. heat with a propane torch to 250 degrees in the area an inch around the weld.......... i use 7018 DC stick on everything..  One short pass, then chip with hammer to get the flux off and releave stress .... after 1 minute, do another short pass or buildup... dont weave the rod, just do short beads.
Edited by steve(ill) - 30 Oct 2022 at 8:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 8:46pm
Maybe easier to buy used one
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 9:02pm
yes.. if you have the time and expertise its worth a try.. If your going to pay someone to weld it, FORGET IT..
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2022 at 7:46am
7018 will wreck the parts. Preheat, use a nickel rod. Or BETTER, braze it with a brass rod and torch. It’s much easier on the iron parts and will prevent carbon from
Migrating into the grain
 boundaries
Edited by 1939Dodge - 31 Oct 2022 at 7:48am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2022 at 7:51am
As Steve says, cast iron is tricky to weld under the best circumstances. After 70 years of heat-cycling, probably near impossible. There are new ones out there, that's the way I've gone. Both of my CA's where new manifolds.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2022 at 10:12am
Better off getting a good used one.  There should be millions of them out there.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2022 at 11:08am
I have a new one from Steiner.  High quality piece.
1951 B
