6080 hitch lift link gear frozen
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: 6080 hitch lift link gear frozen
    Posted: 29 Oct 2022 at 9:02pm
Hello All:
The hitch and lift link (name from parts book) seems to be frozen. Any thoughts before I try and take it off to fix?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 5:45pm
Had to use a little heat on ours as the grease apparently got hard. Greased it until all the old grease pushed out. Not something that gets adjusted often unless a person does a lot of. 3 pt work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 9:12pm
You think an electric blanket might work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 9:14pm
Yeah it is adjusted kind of high right now. I am putting a fence in with a shaver, doing bushhogginh, little road grading etc.
Want to atleast get it level because the bushhog is kind of sideways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 9:16pm
Noooooo, a torch of a some type. I used a small propane torch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2022 at 11:50am
Gotcha, I'll get the torch out :).
