stationary wheel clamps for 210
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: stationary wheel clamps for 210
    Posted: 29 Oct 2022 at 8:05pm
I decided to put the cast center wheels back on the 210 after having pressed steel on it for over 20 years but it had power adjust rims on it when i got it and I want to put stationary rims on it now and I got the wheels clamps from a salvage yard and noticed they were about half and half on being the same kind.
So went to put the centers and tires on today and have discovered they are different heights and just enough that i can't get all 16 on the rim.
I don't seem to be able to find brand new ones online and that is pretty much why I got them from a salvage yard,does any one have new ones or know where i can find original allis chalmers stationary wheel clamps at.
Thanks,
Kevin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2022 at 9:01pm
If someone knows what the original 210 wheel wedges look like for stationary rims i can send you a picture by cell phone since i don't know how to get pictures on here and show you what i have that I got from a salvage yard.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2022 at 9:40pm
Your talking about putting double bevel rims on, correct? Seems they had one size that was larger for 38" rims.
 There was the 18.4 x 34, 18.4 X 38, 20.8 x 38, 23.1 x 30 and then there was the 24.5 x 32 wheels... in the non-power shift wheels.
  In the 210 brochure, it looks like 18.4 x 34 non power adjust was the only 34" available while they list 3 different sizes in the 38" power-shift ... 15.5x38, 16.9x38, and 18.4x38
  Would assume there would be different clamps for different sized wheels.
  Maybe able to find that info in a parts book or at agco parts.  Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2022 at 9:59pm
Parts book lists one wedge for straight wheels and one wedge for power adjust. They are priced so they are available. $30.48 EA
Edited by SteveM C/IL - 01 Nov 2022 at 10:01pm
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2022 at 8:54pm
Double bevel 34" an 38" rims have the same clamps. If you have power shift rims, the cast center is the same but the clamps are angled to the rail. I used clamps from a MF on my 220 PS duals on Mexican hat centers.  26", 30" and 32" rims use a different clamp. They are a wedge style for the drop center style rim.
This page was generated in 0.069 seconds.
