Forklift L80-FPL80-24 ?
jpi72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jpi72 Quote  Post ReplyReply Direct Link To This Post Topic: Forklift L80-FPL80-24 ?
    Posted: 27 Oct 2022 at 8:56pm
An AC forklift is coming for sale.  I have not seen it yet, but this is the numbers L80-FPL80-24.  Is the 80 for 80 horsepower?  What does FPL stand for?
I realize parts will be an issue.  I am assuming that it is an engine that had other uses.
Any help would be appreciated.
Joel
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2022 at 9:38pm
i think the 80 means 8,000 pound lift... or about 13,000 pound machine.
i though an FL was "Forktrk liquid propane" ........ and FP was "petrol"... or gasoline.
Edited by steve(ill) - 27 Oct 2022 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2022 at 5:54am
yes, 80 means 8,000 pound lift,probably good for a tad more too !!
FPD means a diesel powered,THAT I KNOW as I have an FPD50-24-2PS
2PS might mean 2 speed,automatic.
I also know that the driveshaft U-joints( double Carden (?) were never greased. It needs to be replaced ( no needles...still works though, shhh)
Not too sure HOW you'ld get a 13,000# beastie up off the ground for service though...
www.liberatedmanuals.com has 1,000s of manuals, if you put allis 8000 into the 'search' option it'll narrow it down to maybe 20-50, then download 'this might be it',open, read, try again....
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2022 at 9:57pm
Tilt the mast full back.  Place a big wood block under the base of the mast.
Tilt the mast full forward.  Tires will lift off the ground, place blocks under tires.
Tilt mast back and repeat.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2022 at 1:20pm
I think the P means pneumatic tire.
This page was generated in 0.058 seconds.
