190XT Power Director |
Post Reply ![]() |
meells ![]() Bronze Level ![]() Joined: 02 Jan 2022 Location: IN Points: 18 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Oct 2022 at 5:00pm |
I rebult the power director on my 190xt over the winter. Everything was done according to the book. I read on here to use the 7000 plates for clutch pack, so I did that as well. I put everything back together and only had low range. Even when put in high and neutral I only seemed to be in low. Can I get some pointers on what I may have done wrong?
Thanks. |
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1918 |
Simple thing but what I did wrong the first time was not line up power director housing for oil to pass thru to high side.
I appreciate the response. It's been long enough I'll need refamiliarize myself with some of the steps. I believe mine is lined up properly.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21790 |
The passageway is for low side. Always air test a Power Director clutch before rolling tractor back together.
Edited by DrAllis - 16 Oct 2022 at 5:38pm |
Thanks doc couldn't remember was a long time ago when I did mine. Just knew one side didn't work because of that mistake.
Clay ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Udall, Kansas Points: 9856 |
How much air pressure is required for the air pressure test?
Shop air pressure is best, but 50 lbs should be enough to KNOW the both clutches can and will apply.
Thanks Dr. I will write that information down in my power director notes.
Post Reply ![]() |
