camshaft selection
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: camshaft selection
    Posted: 05 Oct 2010 at 9:37pm
Is a d17 cam better for pulling than a WC cam? Thanks,JM
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2010 at 9:50pm
I'm not sure as it's been many years but you may want to check your cam gear and oil pump gear as they are different in those two models.
I just rember buying a cam from a fella that stripped the oil pump gear off.  I didn't need the gear as I ran a crank driven pump.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2010 at 6:46am
the wc is around .240 lift the d17 is around .270 lift. lerio .290 175 .314 measurement takin  at the cam not the valve
