Rusty restoration
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Topic: Rusty restoration
    Posted: 14 Oct 2022 at 9:45pm
I dont really know how to describe this. Has anyone restored anything rusty without painting it? I see pickups and such that are not necessarily restored, more like preserved. Looks like maybe they Clearcoat right over the rust??
The reason I ask is I have an Allis garden tractor that is a nice original, although does have some rust. I have it torn down, just wondering what I can do to clean it up but not paint it. I washed the hood three times, one coat of rubbing compound, and one of wax, and it looks incredible, but the paint was in good shape. The white dash is reddish brown with rust, and the inside of the frame is rusty from 20 years sitting with acorns and walnuts and crud in it. Should a guy use rubbing compound and wax where the paint is good, and just wire brush the rust and then clear coat it? Just looking for ideas and experience, thanks.
The mechanic always wins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 9:52pm
Edited by littlemarv - 14 Oct 2022 at 9:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 9:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 9:56pm
So here is what I'm talking about. The hood and seat pan cleaned up real nice. But the frame is a lot more rusty.
Edited by littlemarv - 14 Oct 2022 at 9:57pm
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 10:03pm
No real answer to which way to go. Some survivors look really cool kept that way and others look right all painted up. Problem sometimes is they get too pretty to use much and that is not fun or good for the machine. If rot is too extreme it may be necessary to go all out to prevent further deterioration, if not structural or seen maybe put it together loose and see what you like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 10:16pm
I would wire brush the backside that has excessive rust.. You dont have to go to clean metal........ then WAX like you did the paint portion.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 7:22am
I know this is an AC site but that lineup of Case tractors has made me guilty of breaking at least one commandment; I own a Case 224 lawn tractor and love it Thumbs Up Always on the lookout for parts and accessories.
Ross D. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2022 at 8:32am
   Hi.
   Marv, what would you think of a thorough cleaning and then give it a clear coat of rattle can spray paint. The patina would remain; and, the metal would be protected.
   Ross D.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 10:08pm
get the big loose stuff off and keep agood coat paste turtle wax on it
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2022 at 11:14pm
Wire brush rusty area to knock off loose stuff, brush on muriatic acid, let sit for a few mins, rinse well with water dry well with compressed air and then clear coat or wax. Proper PPE, and precautions apply. The acid wash and water rinse is to stop the chemical reaction of rusting. If you don't do something to stabilize the rusting, it will continue under the wax or paint. There are other products to use instead of the acid that work well too, but muriatic works well, and is way cheaper.
I am still confident of this;
Wait for the Lord;
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2022 at 5:55am
Lou, I been waiting for someone to suggest what you did.  Also using Phosphoric acid is or was common for the same purpose.  As I foggily recall, when you combine iron oxide (rust) with phosphoric acid you get iron phosphate which is an inert material.
Lotta times that stuff is labeled as bare metal prep.  I used to get it off the shelf in Home Depot in the metal prep section.  Wink
Edited by Dave H - 20 Oct 2022 at 3:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2022 at 1:38pm
Place I worked at made plates that were grid plates (raised dots) used for positioning machines by counting chemical milled dots on plate . We used a phosphate bath to soak the plates in for a time , then dry them in a drying oven - after they were coated with a oil which was removed when plate was put into final assembly - the phosphate kept rust from forming when used in controlled atmospher .
  After chemical etching and before phosphate bath the plates were soaked in a dilute 20% solution of inhibited muriatic acid to remove any surface rust which may have formed .
Edited by Coke-in-MN - 20 Oct 2022 at 1:43pm
Dorix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dorix Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2022 at 5:46pm
  I usually clean all the loose rust off and scrub it good with warm water and Comet Cleaner powder. I don't know how good it is but seems to work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2022 at 10:55pm
Dave, actually i meant phosphoric acid! I will go back and correct my post.
Thanks
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2022 at 10:58pm
Phosphoric acid, not muriatic
Edited by LouSWPA - 23 Oct 2022 at 10:59pm
Wait for the Lord;
dee_veloper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dee_veloper Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2022 at 7:53pm
  If the paint is gone, replaced by rust, what is being preserved?  Preserving rust seems odd. Remove the rust and it'll be down to bare metal which is certainly not the original look.
 To me, preserving only works if it's like the hood and the original is able to be brought back to life.
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2022 at 10:26pm
Rat Rods is one application.
Some people like the 'show' tractors to be shown in their working clothes, not like it just came off the show room floor. But the trick is to preserve the 'patina' so that it does not get worse, w/o changing it. That's why they don't remove the rust, just knock off the loose stuff.
Wait for the Lord;
This page was generated in 0.301 seconds.
