Air compressor
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: Air compressor
    Posted: 13 Oct 2022 at 7:17pm
The air compressor on 2006 prevost motor coach builds to much air pressure..  Replaced the unloader valves in air compressor head, new governor, changed spitter valve.
Not understanding the operation completely but seems for some reason unloader valves are not holding intake valves open assuming that's how it works.  Any one with experience?? Thanks,   Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 6:45pm
Update:::::: After much head scratching muttering and mumbling took the new governor off and replaced with a known working one cured the problem.  New one no good right out of the box!!!!
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2022 at 7:20pm
Most frustrating thing when you replace parts trying to fix a problem and the new part doesn't work.
