Steering clutch T/O bearing 'wick'.
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Topic: Steering clutch T/O bearing 'wick'.
    Posted: 09 Oct 2022 at 8:52pm
Trying to figure some way to get some grease to the steering clutch throwout bearings. My machine has the hose from bevel gear compartment to the bearing, with a wick-type lube setup. I'm sure by now, that wick is dried up to the consistency of a #2 pencil. The hose shown in the parts manual apparently threads into bevel gear housing on one end, and on the other, threads into a street elbow and then to the bearing housing . It appears to have no swivel device on it, so, do you have to remove the bearing to remove this hose? I want to install a grease gun hose into the bearing housing and mount one end on the steering clutch cover so I can lube it.
Semper Fi USMC    1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 7:02am
just cut it and put an 1/8 pipe plug in bevel housing and screw in a new grease hose
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2022 at 11:37am
Plug that fitting in case , then get a grease gun hose and run from bearing - through plate on steering clutch housng and install grease nipple . can then be greased without having to remove cover or depend on wick
This page was generated in 0.367 seconds.
